Coilovers where to get your alignment.
Old Feb 25, 2010 | 07:54 PM
redline4's Avatar
Okay well I got a couple of questions as far as alignment with coilovers. Basically what type of place should I look for when finding a shop to do the alignment for my car after coilovers. We have a tire places but Honestly I don't know if I trust them. Should I find a motorsports type shop where they specialize in is tuner cars? Is the alignment the same as if you just had a normal strut w springs? Last but not least anyone have any suggestions in Memphis where I could go?
Old Feb 25, 2010 | 09:12 PM
Boosted_Cobalt09's Avatar
well i guess its a matter of what you want.....do you want a race alignment or do you want your average alignment?
race alignment would require your own personal camber preferances, caster preferences, ride height adjustment and so forth....more then likely you will need to find a shop that will do those alignments.
regular alignment.....pretty self explanitory. they just get the car to oem specs.
Old Feb 25, 2010 | 09:18 PM
ls1fbody's Avatar
Haz l33t wheelz.
Anywhere that does alignments. Luckily there are a lot of performance oriented shops around that will simply ask what you want the settings to be haha. If not you have to look the GM stuff up on your own. Most shops that do alignments on a regular basis will have that though.
0 toe.
P.s. Front end alignment only!!!
You cannot align the stock rear end.
Old Feb 25, 2010 | 09:20 PM
redline4's Avatar
Im just going for the best drop. I don't plan on doing any autox or anything like that.
Old Feb 25, 2010 | 09:26 PM
hatrickstu's Avatar
best drop is not always smart. ask me how i know. anyways, firestone (where i work) is the best alignment my car has ever had. seriously.
Old Feb 25, 2010 | 09:33 PM
redline4's Avatar
please explain.
Old Feb 25, 2010 | 09:35 PM
hatrickstu's Avatar
think of your axles.
Old Feb 25, 2010 | 09:37 PM
ls1fbody's Avatar
Haz l33t wheelz.
Originally Posted by redline4
please explain.
Too low, axles too long, CV's cry mommy.
Old Feb 25, 2010 | 09:41 PM
redline4's Avatar
All im trying to do is get rid of some wheel gap. Im not slamming it to the ground.
Old Feb 25, 2010 | 10:27 PM
basically slamming the car to the ground causes your axles to bind...... also you will having turning issues. it looks kool but its definately not good for the car.
Old Feb 25, 2010 | 10:36 PM
conerboner's Avatar
I got mine done at firestone as well... only thing is they couldn't get the camber to be 0.
Old Feb 25, 2010 | 10:40 PM
ls1fbody's Avatar
Haz l33t wheelz.
you don't want the camber at 0...
Old Feb 25, 2010 | 10:53 PM
conerboner's Avatar
well i don't think it's supposed to be off as much as it is... I lost the sheet that had all the numbers on it but just by looking at it the top is in a lot more than the bottom...
Old Feb 25, 2010 | 10:58 PM
shawn672's Avatar
wait you cant align a stock rear end... lolz
Old Feb 25, 2010 | 11:41 PM
hatrickstu's Avatar
yea you actually cant
Old Feb 26, 2010 | 12:28 AM
yeah can align it but theres not much adjustment what so ever.
Old Feb 26, 2010 | 12:44 AM
ls1fbody's Avatar
Haz l33t wheelz.
only way to align it is by loosening the body mount bolts and shifting the whole beam. 99% of the shops out there won't even think about considering it.
Old Feb 26, 2010 | 12:47 AM
but still.....its adjustable lol......oh by the way will hop on aim i gotta show you something
Old Feb 26, 2010 | 12:54 AM
ls1fbody's Avatar
Haz l33t wheelz.
Its not safely adjustable...
Old Feb 26, 2010 | 01:01 AM
Stamina's Avatar
So what about when you have ones with adjustable camber? Do you have to get it aligned to the camber plates in order for the camber markings on the plate to be correct/in sync?
For instance, would I first set the plates to say zero and then tell them to set camber to 0 and then I'm good to go after that?... or would I already be good to go after install?
Old Feb 26, 2010 | 01:04 AM
ls1fbody's Avatar
Haz l33t wheelz.
yes, if you set the camber plates to 0, and they adjusted the knuckle mount to 0, you should be set to dial in camber with your upper mount plate. Assuming the know what they're doing, and set it to true 0.
Old Feb 26, 2010 | 01:07 AM
Stamina's Avatar
Thanks for the info.
What is stock SS/TC camber btw?
Old Feb 26, 2010 | 01:35 AM
ls1fbody's Avatar
Haz l33t wheelz.
not sure haha. I would ask the dealer, or your alignment shop. they have access to that stuff.
Old Feb 26, 2010 | 01:43 AM
100% METH's Avatar
Ohh... axle binding....
good excuse to upgrade em anyway? ya
Old Feb 26, 2010 | 01:44 AM
ls1fbody's Avatar
Haz l33t wheelz.
Making them stronger does not lessen the problem of binding axles Steven...
