does anyone make a direct bolt in strut/shock?
Ok so heres the deal, already got lowering springs, and im on stock shocks. I know that koni makes them however you have to hacksaw your stock ones in the front, they are inserts not a full kit. Does anyone make something you just bolt on?
im pretty sure they dont... other than factory replacements
Yeah exactly how do these work? ive been reading that you need to "modify" these.:eek:
oh kyb makes a oem replacement... supposed to be better than oem
The changeover to the Koni's is really quite simple if your worried about the install.
TC shocks are best.
coilovers?
The rear konis bolt in, the fronts you basically hacksaw the top half off then drill a hole in the bottom and the konis are a "insert"
GM makes some......they are what was used by the quickest real street FWD car to ever lap the Nurburgring. ;) Pretty sure theyll be good enough
Originally Posted by Stiner
(Post 4571298)
i have a feeling you knew that though.... |
Actually IIRC KYB makes the fronts and Sachs makes the rears ;)
Originally Posted by Maven
(Post 4571501)
(Post 4571260)
(Post 4571501)
How do I tell which is which crate engine dept just lists FE5 thats what they are all called my 07 says it has a FE5 too
(Post 4571260)
Originally Posted by Cefaln452
(Post 4571724)
kyb makes all 4 corners fyi
Originally Posted by Rodimus_Prime
(Post 4571774)
(Post 4571724)
im lowering my 2.4 with ksports and i was told all i needed was tc rear struts
tc front struts. There is no struts on the rear
just shocks on back |
what do i need in the rear then im not too educated on suspension
just shocks on back
ok thanks
I'll help u with install if u want
