Drum to dis
Old Apr 9, 2015 | 11:03 AM
User 60923's Avatar
Drum to dis
I have A cobalt lt with 5 lug I found a wreck lsj would I just need the ebrake cable from the lsj and the caliper and the rotor for the swap or would I have to change the whole rear axle
Old Apr 9, 2015 | 04:02 PM
rains_crusader's Avatar
You'll need to either swap the entire rear axle or buy a disc conversion caliper bracket (Powell makes one). The drum axles don't have any caliper mounting tabs on the hub flange plate.
You'll need to change out your abs /proportioning valve assembly so your brake bias is correct. I found a used one on eBay. It's a direct swap. No programming needed. 05-06 must use an 05-06 assembly. The 07-10's should all be interchangeable but I can't say for sure.
Yes, you'll need different e-brake cables. New ones are under $10 a piece.
Old Apr 9, 2015 | 06:55 PM
User 60923's Avatar
Alright thanks for the info
Old Apr 9, 2015 | 07:15 PM
no_ss's Avatar
I thought the break between the different parts was 05-07 and 08-10
Old Apr 9, 2015 | 09:40 PM
For most things it is. If you check out abs pumps on eBay, you'll see the difference. The 05-06 has 2 brake line inlets and 4 brake line outlets all on the top side. The 07+ has four outlets on top and 2 on the side. Also, some of the electrical systems were upgraded in 07. so, I'm not sure if the modules would be able to communicate if they were mismatched. A good example of this would be the cluster. An 07 cluster won't work in an 05-06
09SSlow
Sep 28, 2015 12:37 AM
SS4LIfe
Mar 29, 2006 01:03 AM
GotBoost?
Feb 19, 2006 01:13 AM
badg1rl
Forced Induction
52
Jan 26, 2006 07:47 AM
