Fe5 / Koni Question
Old Jan 10, 2012 | 02:33 PM
INTENSEL61's Avatar
Question Fe5 / Koni Question
Happy New Year, CSS Family!
My daily driven 2007 LS Coupe needs new struts. I'm lowered on Tenzo R lowering springs. What do you suggest (other than coilovers)?
(1) Koni Front and Rear
(2) Fe5 Front, Koni Rear
(3) Other: __________
What is the advantage of Fe5 up front and Koni in the rear THAN going Koni all the way around?
Thanks in advance!
Old Jan 10, 2012 | 02:39 PM
RHZ's Avatar
RHZ
Fe5 front and rear... you can get those for dirt cheap.
Old Jan 10, 2012 | 02:41 PM
INTENSEL61's Avatar
I understand they're great but how do they compare to Koni's other than price? Will they last long with my lowering springs? Thanks!
Old Jan 10, 2012 | 02:57 PM
Whitnith's Avatar
Koni doesn't have a true front for our cars, it's just an insert. That's the only reason people don't do them. If you're not doing any sort of racing, the FE5 all around will be just fine.
Old Jan 10, 2012 | 09:40 PM
Sharkey's Avatar
fe5 will work just fine, however if your racing some adjustability for the rear is nice to have.
Old Jan 11, 2012 | 03:01 AM
Wangspeed's Avatar
If you have an aftermarket rear swaybar, the FE5 rear shocks are underdamped. Frankly, I prefer more rebound for the front as well, which is why I'm running Konis all the way around, with the XXX bar. Even with the hardcore bar, the rear way too underdamped.
Old Jan 15, 2012 | 02:47 AM
EmperorJJ1's Avatar
under damped?
Old Jan 15, 2012 | 02:50 AM
FryLoch's Avatar
under damped?
Yea, under damped, as in it needs to be more damped. I use a pressure washer to over come this issue, rear of my car is very damp afterwards.
Old Jan 15, 2012 | 02:55 AM
EmperorJJ1's Avatar
lol ******. sorry idk **** about suspension but im trying to learn a lil b4 i order the konis
Old Jan 15, 2012 | 08:49 PM
BLue NoTe's Avatar
A spring will oscillate freely on its own, ie boioioioioioioing. Shocks are there to control the springs motion, not so much to add to the spring rate. Underdamped means that the spring would compress then extend over and over again, the shock is too soft to make it a perfect compress then extend to normal. An underdamped car feels bouncy and causes tire load and slip angles to vary too much.
Overdamped would mean the shock is too stiff and doesn't allow the spring to compress or extend as far as it normally would. This would make a car hop over bumps, and a tire not touching the road can't grip it
Old Jan 15, 2012 | 10:37 PM
Wangspeed's Avatar
One thumb for getting dampen v damp correct (Fry Loch failed), and another for knowing what's up.
It is possible to overdamp the rebound with Konis if you turn them up too high. Less is more. They really only need somewhere between 1/4 to 1/2 turn off full soft, depending on your setup and the road conditions.
Old Jan 16, 2012 | 02:04 AM
BLue NoTe's Avatar
What do you set the front on? I still have the FE5s up there and can feel low speed wobbling
Old Jan 16, 2012 | 03:07 AM
EmperorJJ1's Avatar
ah ok so where do u have urs set? i was planning full soft to be honest. trying it out then adjusting from there
Old Jan 16, 2012 | 02:27 PM
Wangspeed's Avatar
I have the fronts around 1/4 off full soft for daily driving. Up to 1/2 off full soft for track. The rears are set about 1/2 turn off full soft, I think. I may have them a little bit under that, closer to 3/8. There is a big difference between 3/4 and 3/8 off full soft in the rear. Like WAAAAY too much rebound, even though I have Pedders and the XXX bar. Most people should stick with 1/4 off full soft in the rear.
Old Jan 16, 2012 | 04:11 PM
BLue NoTe's Avatar
Yeah I'm at 1/2. Street handling has improved, gotta wait til March to hit the cone course. I'll probably get the front Konis right before the SCCA nationals in Lincoln
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
Coballin13
Sep 25, 2015 08:43 AM
