Front end clunk need HELP!
Old Aug 4, 2013 | 10:10 PM
Shane H's Avatar
Ok so I've looked at all the threads and started changing parts but I am now at a standstill and need some help. I have a loud clunking noise coming from the passenger side. It happens at damn near any mile an hour when hit bumps of any size ( haven't had the car over 50 to hear the noise). I've already done new sway bar end links. Could the CABS be making the noise? There's no leaking from my ksports either. So I am stumped. 😵
Old Aug 4, 2013 | 10:25 PM
buildmeanempire's Avatar
Did you get under and look at the rubber on the CAB's? If not, I would do that before replacing in case they are not torn or seperated from the race.
Sent from my Nokia 3100 using CobaltSS
Old Aug 4, 2013 | 10:31 PM
Shane H's Avatar
I looked at them when replacing the end links but couldn't tell if they were good or bad. Are there any signs I can check for while driving. The noise kind of just came out of no where.
Old Aug 4, 2013 | 10:40 PM
I don't know of what the signs would be. Question though. When you turn your steering wheel quickly side to side does it make any noise. If so then it may be your steering shaft.
Old Aug 4, 2013 | 10:52 PM
Shane H's Avatar
Zero noise and I've determined that its coming from the passenger side for sure.
Old Aug 4, 2013 | 10:58 PM
Well if the CAB's look good and you just replaced the endlinks.... maybe sway bar bushings? Hopefully John can pop in here or someone that could be more helpful.
Solaris99
28
Mar 15, 2017 01:22 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Bohb
Sep 27, 2015 09:11 PM
grampss
Sep 27, 2015 08:51 PM
