front end shutter
Old May 12, 2010 | 12:00 AM
advise's Avatar
front end shutter
so after installing ssc springs i have a side to side shutter at low speed and goes away at high speed
searched and it seems to be a common problem from axle binding, and the tabs are facing in
is their any solution?
Old May 12, 2010 | 10:17 PM
cujo's Avatar
I have that same low speed acceleration (1000-2000rpm or so) front end shudder/shimmy with my Sportlines. It is very annoying. Hopefully it goes away whenever I get around to trying out the Eibach Pro-Kit instead.
I asked the GM tech at the dealership WTF some do it and others don't, and he said basically b/c no two cars are identical spec wise or something, and it is the new angle of the CV joints causing it. That was about the best answer that could be given apparently. We both went out for a test drive a few times so I could prove what was happening. I used a bottle of water as a visual, as it would shake every time.
Old May 17, 2010 | 08:53 PM
advise's Avatar
i hope when i switch to pedders i dont have this problem
Old May 17, 2010 | 08:56 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i used to have that front end vibration too but when i went to ott stage 2 rotated mounts it went away
Old Aug 4, 2010 | 02:41 PM
Hodz's Avatar
Did the vibration occur only you accelerated? Or was it all the time? Also how would transmission mounts fix the problem? Whats the explaination behind it?
Solaris99
28
Mar 15, 2017 01:22 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Bohb
Sep 27, 2015 09:11 PM
grampss
Sep 27, 2015 08:51 PM
