Front end sitting high
Old Mar 18, 2015 | 12:26 AM
Bthor98's Avatar
Just bought a new cobalt ss supercharged, the guy replaced the front struts and is sitting higher then the back... Well it break in and lower on its own eventually?
Old Mar 18, 2015 | 01:10 AM
chris88z24's Avatar
Your shocks are probably blown. Were those ever replaced?
Old Mar 18, 2015 | 01:23 AM
Shocks dont affect ride height
Old Mar 18, 2015 | 02:23 AM
Bthor98's Avatar
They where just replaced
Old Mar 18, 2015 | 10:24 AM
Viperoni's Avatar
The front may settle a bit, but the rears might be sagging too.
How big is the difference between the front and rear ride height?
Old Mar 18, 2015 | 12:02 PM
chris88z24's Avatar
Broken springs then.
Old Mar 18, 2015 | 12:13 PM
Bthor98's Avatar
Ill check the difference in wheel gap later and i dont beleive thats it
Old Mar 18, 2015 | 12:57 PM
Or the guy used the quick-strut and put in the base model because it was cheaper
Old Mar 18, 2015 | 01:06 PM
LNFTX's Avatar
Boom
Possibly fe5 on back and fe1 on front
Old Jun 28, 2020 | 08:19 PM
DynasticAxis892's Avatar
I have a similar question
So I believe you've helped me in the past. But my right side took a hit recently and I ended up bending my OEM rim. Got a new set of tires and rims but the side that took a hit is sitting lower then the other side. My first thought was that I blew out the right side suspension. Does anyone have insight as what I could be dealing with? It still rides fine. And no steering problems. It's just a visible difference. I haven't driven it very much at all though because ide like to figure out what's up.
Old Jun 29, 2020 | 02:35 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
You need to check the springs. As he said your shocks/struts doesn't affect ride height - just the springs. Well, those and weight. But I'm guessing you'd know if you suddenly had an additional 500 lbs on one side of the car.
cOHbalt
Mar 27, 2013 02:43 PM
VRCobalt
Sep 12, 2008 10:58 PM
jojot
Jul 7, 2007 03:27 PM
farfrmnormal
May 3, 2007 04:56 PM
