Getting an Alignment
I was wondering would it really hurt my tires if I go around a month before getting my alignment done after I do my spring install?
Also can I get a place just to check my toe for me. I went today and check the prices and they aren't to bad but they want to check the entire thing and I only need to fix the toe on the car.
Trust me, get the alignment.... It only costs $80 and is worth it. Your toe will definitely be off after the springs and since your car isn't brand new it will be a good idea to get the other numbers checked as well.... better to be safe than sorry....
you could probably get away with it...depends on how much and how aggressive you are in driving it... you will get some extra wear in the tires, but if you baby it then it shouldn't be too bad....
If you can't afford what, $80 or so, right now, hold off on the springs until you can.
My $0.02
Definite maybe on that one......I have seen tires turned to trash in a few days with the toe only a little out of spec. If you only put 200 miles on, prolly ok. If you drive like I do (2000+ / month) then I would get it done pronto.
My $0.02
My $0.02
DANRICKARD
Oct 1, 2015 12:08 AM
