Good Replacement REAR SHOCKS??
Old Jan 8, 2014 | 04:21 PM
cranemaster's Avatar
So ive taken half my car apart to find a clunk in the rear, today I actually took the day off work to take the whole suspension apart and only got to the rear shocks.
After completely removing the rear passenger shock, its obviously toast.. a little ride around the block with it removed and the clunking is gone.
Problem: Non of the dealerships carry the OEM Cobalt SS/TC 25793745 - ABSORBER, and they want $140 a shock.
Im thinking getting a generic Monroe 5779 shock meant for the base models is probably a bad idea too.
Given the position im in that I have to order a new shock(s) I figured I could put in stiffer ones...
Is there a 'go too' set to grab for the SS/TC? Or just get the OEM online?
Thanks!
Old Jan 8, 2014 | 04:30 PM
Xmetalhead2003X's Avatar
Koni rears but they're more expensive. I've been happy with the fe5 kyb I put on mine. Price is good too.
Old Jan 8, 2014 | 06:24 PM
intel's Avatar
Also with the Koni's if I am not mistaken you get a lifetime warranty, might be something you want to consider if you got the cash for them.
Old Jan 8, 2014 | 11:07 PM
Skys the limit sort of. Im only interested in the rears though, and ZZP sells them as a front and back set. Where can you buy the koni yellows, but just the rears?
Old Jan 9, 2014 | 01:10 AM
andrewcarr1993's Avatar
If you send a message to ZZP I believe they will split them up. Believe their a bit cheaper on tire rack but I actually bought mine through TWM. I have Koni's in the front and rear, highly recommend them.
Old Jan 9, 2014 | 01:26 AM
Grave's Avatar
I have oem rear shocks and Koni rear shocks for sale. Both sets have about 20,000.
Old Jan 9, 2014 | 01:27 AM
ThexGovenor's Avatar
look at crate engine depot for OEM rears. They are your next best option to Koni. Good luck
Old Jan 9, 2014 | 07:45 AM
THMotorsports had the best deal on Konis last I checked, but that was a few months ago
Old Feb 15, 2014 | 02:47 PM
DJVC's Avatar
Have you looked at Amazon? Amazon has them for $43
Amazon Amazon
Old Feb 15, 2014 | 02:49 PM
chris88z24's Avatar
How much did yours clunk? I have a clunk when I go over speed bumps but never anytime else. Always thought it was the (stock) exhaust bouncing around.
Canadia's Avatar
I clunk too... On more aggressive corners as well
chefhhr
Oct 26, 2015 10:36 PM
Cptnslo
Sep 24, 2015 09:32 AM
ATOMbomb
Sep 11, 2015 10:48 AM
ROADKONE
Sep 9, 2015 02:32 PM
