Has anyone done this?
2007, I am doing this for sure in about 2 weeks or so and was worried if the 18"s were to big for the 2.0" drop. BTW what is your offset and also your rim is 18x?
Here is the data I collected off an independent site:
18X7 +42MM 26.5LBS
There is still a little wheel gap, I have never had a problem rubbing tires at all and im running 225/40/18 tires.
Also change out your shocks and struts for Koni Yellows, otherwise your ride is going to suck and shortly there after your going to have blown shocks.
18X7 +42MM 26.5LBS
^^^ They wont blow if you dont cut the bumpstops.
My tenzoR's dont have cut bumpstops and the struts are holding up well and I live on an unkept gravel road.
thanks to the both of you that responded, also i wanted to get these http://www.1010tires.com/wheel.asp?w...2+%2D+Chromium but i dont know if they will fit, they are 18x7.5 and 42 mm offset , will that work?
thanks
thanks
