Help - Cutting bump stops for sprotlines
Old May 24, 2006 | 12:13 AM
Asphalt Assault's Avatar
I have a set of used sportlines. no instructions on how to cut the bump stops. can some won help me out.
Primetime may be able to help me out.
Old May 24, 2006 | 12:38 AM
I went to the Eibach website just now and there is nothing there.
Old May 24, 2006 | 05:35 AM
DARK AGE 53's Avatar
I did a search and came up with this https://www.cobaltss.net/forums/show...=cut+bump+stop
Old May 24, 2006 | 05:36 AM
Brandon97Z's Avatar
trim 13mm off of the rear bump stop. I didn't trim the fronts, i dont even think we have bump stops up front but i could be wrong. i forgot to look, and didn't remember till after i put everything back together.
Old May 24, 2006 | 10:42 AM
GSoccer24's Avatar
so it's only the rear that has to be trimmed?
Old May 24, 2006 | 11:08 AM
thankyou for the link. you just need to know what to type in the search. I have to admit and it is apparent this not a skill I shine in. I at least made an attempt!
Old May 24, 2006 | 11:18 AM
Yeah the rear only and it makes sense to me. the front is not lowered as much as the rear. the rubber on the front goes around the shaft of the strut and the strut mounts are also rubber mounted. the strut bumper will have more squish to compenstate. again only an inch lower so its not that drastic.
the rear is a solid block on the back. it is not as plyable and does not have a hole in the center to squish out easier. the drop is close to 2" to in the rear so it needs some help. pull out the hack saw.
Thanks again Dark Age 53.
AND THAT CONCLUDES ANOTHER EPISODE OF "THE LOST NEEDING GUIDANCE" on the Cobalt SS Channel. TUNE IN FOR MORE EXCITING ENTERTAINMENT AS THESE GUYS TWEAK AND GROW BIGGER, BETTER, and MORE COMPETITIVE MACHINES IN THEIR GUEST FOR DOMINANCE IN TUNERVILLE.
Okay. Dont flame me. That was gay but I think you get my drift. I come here for advice and I like to share my knowledge too. thanks to all
Old May 24, 2006 | 12:22 PM
You're welcome. As I've said in other threads, we need a good write with pics on this mod.
ssnipes, drive your car down here to Michigan and we'll get those springs installed and do a good write also.
Old May 24, 2006 | 12:56 PM
Yeah I will do that what is your address. I think I could get there in 4 days as I want to sight see. oh make that five days cause I want to race. oh make that 7days as I have to wait to see if I won the lottery! LOL
Honestly I would take up on a offer like that but it will be cheaper for me to pay someone to put them in. I plan to take pics. Maybe I will do a write up then and it is done by experts. The guys I know wont like the picture idea but I dont need much.
Old May 24, 2006 | 01:47 PM
ninja44's Avatar
There is no need to trim the bumpstops! I've been running Sportlines for almost a year and it does not bottom out.
Old May 24, 2006 | 02:03 PM
GSoccer24's Avatar
yeah i didn't trim mine and i've been fine
Old May 24, 2006 | 02:32 PM
O.K, be that way, just kidding.
In my opinon a good write up should have a photo of everything that is mentioned in the write up, taking photo's as you do the install would make the install take a little longer to do but it would help out a lot of guys in the future.
Like you, I'm not good at making it look like an expert did the write, I posted this in another thread showing how a good write should be done http://users3.ev1.net/~cnl1/firehawk/subframe/index.htm . dudeman from the old SLP forum put that together, he did a great job and that's what I'd like to see done here with the lowering spring mod.
Old May 24, 2006 | 02:37 PM
wikkymaster's Avatar
hmm i never trimmed anything for my pro kit
Old May 24, 2006 | 04:33 PM
Matty's Avatar
Same here. Except for the year part.
Old May 25, 2006 | 08:25 PM
JapEatr's Avatar
South Central *********
trimming is not required on SS/SC
Old May 26, 2006 | 12:08 PM
biohazard's Avatar
Get low
im running tenzo's on my base model for a while without trimming.,... it feels fine, although train tracks suck
Old May 26, 2006 | 08:56 PM
CobaltSS422's Avatar
I was wondering the same thing as i'm installing mine tomorrow. But not trimming the bump stops is great. 1 less step to do then. I trust JapEatr on what he says as he is a suspension tech, i guess u can call him, and from what i've read from his posts he seems as a perfectionist as well.
JapEatr: I know you recommend notching the front but is it really necessary? I know you will be able to adjust camber but is it really that much off? just curious
Old May 26, 2006 | 11:19 PM
JapEatr's Avatar
you will need to adjust camber otherwise it will pull toward the side with the most camber, in order to do so it will require notching the bolt hole with a grinder, but after aligning mines_better & TXRLUs, i would say notch the top bolt hole only, this allows for gradual adjustment +- about a degree each way
Old May 26, 2006 | 11:22 PM
JapEatr's Avatar
sounds like you and i have similar mods done, i installed stage 2 myself today (in between other cars of course)
and yes i try my best to hold my work to a higher standard than your run of the mill guys, thanks for the vote of confidence
Old May 27, 2006 | 12:33 AM
biohazard's Avatar
Get low
they also make a camber kit for $20 it works great
Old May 27, 2006 | 09:47 AM
So notching it would be grinding the hole bigger back and forth?
Old May 27, 2006 | 12:41 PM
I was just reading the info that came with the Sportlines and it says to cut the bump stops.. 30mm for front and 15mm for rear.. but i'm wondering if that is for regular cobalts and not the ss/sc because up top it says 2005-up cobalt
Old May 27, 2006 | 02:10 PM
Now its there that cutting the bumpstops may help
All we are doing is allowing a little more supension travel on a hard hit so you dont feel it through out the car and it will enhance handling on the hard hits. it can mean the difference between skipping through a corner (hit bump stop) or absorbing it with adequate suspension stroke (bump stop cut) and still able to hug the corner.
Pro kit would not need a trim. LS and base cobalt may require the cut and SS/SC no cut. That is why I want some one to send me the copy of Eibach's instructions that came in the box.
SOme one help me out please.
Old May 27, 2006 | 02:11 PM
Your super that is helping me. What did you do in the end? no cutting?
I think I will call Eibach
Old May 29, 2006 | 01:33 AM
I actually ended up cutting the bump stops the way it said. The car handles AMAZING
