help! fe5 on an lt
Old Sep 11, 2010 | 03:01 PM
chevysssc's Avatar
help! fe5 on an lt
i searched with no success but my younger cousin has a 07 lt and wants to know if fe5 suspension is a direct fit. she needs1 lower control arm 2 and struts. the shop wants to charge her $788 for both struts and $225 for lower control arm. create engine depot is cheaper all around so we are thinking ss/tc shocks/struts, and both fe5 lca's with ss/sc springs question is do they all fit on a 07 lt?
Old Sep 11, 2010 | 07:15 PM
chevysssc's Avatar
Old Sep 11, 2010 | 07:19 PM
dandaman15's Avatar
Originally Posted by chevysssc
Yes the struts and shocks are direct fit along with the springs. I would really get SS/TC springs since they are made to go with FE5 struts and shocks. If you need lower control arms you have to get the SS/SC FE5 ones because the SS/TC ones wont fit.
Old Sep 12, 2010 | 02:37 PM
YelloJelloCobalt's Avatar
Almost correct. The SS/TC FE5 LCAs will fit, but you have to make the hole for the control arm bushings a little bigger. I can't remember exact dimensions, but the diameter on the SS/TC bushing is slightly more than that of the FE1 LCA. If you're comfortable with making that kind of mod, go for it. I can confirm that it WILL work though since I've had SS/TC shocks, struts, LCAs, and Pedders springs on my LS for months with no problems
Old Sep 12, 2010 | 02:43 PM
dandaman15's Avatar
So what did you do to make it fit? I was told because of the different front knuckle they would not match up and your better off with the SS/SC ones. This is great to know because I have been wondering this for months.
Old Sep 13, 2010 | 02:11 PM
I can't remember specifics, but all you really need is about a 2 or 3 inch long circular grinding tool (I can't remember what diameter the one I used was, sorry) to make the hole for the bushing ever so slightly larger. Without any modifications though, the SS/TC LCA's bushing ALMOST fits. I didn't know the bushing was larger until I had the new LCA on the car. Big surprise to say the least, but it worked out. I think if you were installing the LCA then you'd see how little a difference there really is size-wise. It's a fairly easy little modification to make if you have the courage to do it.
Old Sep 13, 2010 | 02:20 PM
ItalianJoe1's Avatar
The difference is minor, less than 1mm I believe. You can expand the ball-joint clamp area of the knuckle, install the LNF control arms, and re-clamp, with no issues.
Old Sep 13, 2010 | 02:40 PM
^That works too. Whatever is easiest for you.
Northindy
Oct 31, 2015 01:35 PM
Coballin13
Sep 25, 2015 08:43 AM
dieGone
Sep 23, 2015 10:20 AM
bumblebee06ss
Sep 8, 2015 11:28 AM
