help with new spring rates..
so i have the HSD coil overs in my car at the moment, and ive been searching for front swift springs but i see they come in different sizes. was just wondering what size would be ideal?
the sizes are here:
SWIFT COILOVER REPLACEMENT LINEAR SPRINGS 5 INCH LENGH 2.5IN/65MM ID
SWIFT COILOVER REPLACEMENT LINEAR SPRINGS 6 INCH LENGH 2.5IN/65MM ID
SWIFT COILOVER REPLACEMENT LINEAR SPRINGS 7 INCH LENGH 2.5IN/65MM ID
SWIFT COILOVER REPLACEMENT LINEAR SPRINGS 8 INCH LENGH 2.5IN/65MM ID
the sizes are here:
It all depends what your goal is. The longer the spring the more travel you're able to have but if you are wanting to go super low stance nation type a shorter spring with a higher spring rate would be ideal. But if you are wanting to enjoy the car and drive aggressively going with a longer spring with a moderate to high spring rate can give great handling with decent suspension travel and would give comfort and handling together.
i have 14K for the rear, the plan was to get 12K for the fronts.
12k is a pretty heavy spring. I've got 8k in the front and 9k in the rear on my Stance coils and I want to go to a square 7k or 6k setup as it is too stiff for me and probably also too stiff for the suspension to perform properly.
i would like stiff because of rubbing issues lmfao....
