Hit a pothole :(
Hit a pothole :(
I hit a nasty long pothole and now my right front suspension feels off. Doesn't feel like it handles vary well anymore
I thought maybe it was the tie rod but I tried grabbing the tire, moving it side to side and it didn't seam to budge much. I guess my alignment could be off by a hair but would that cause the car to feel like it handles like ****. When I let go of the wheel it'd say it doesn't really pull to the right.
I have the car off the ground right now in the garage, is there anything else I should look at?
I took a pic of my tie rod...Does it apper to be in decent shape to you guys? \/
Last edited by rallyracer; Feb 28, 2010 at 02:06 PM. Reason: Automerged Doublepost
other side looks the same. The right side was the side that went into the long nasty pothole gouge in the road. I thought I had blown a tire so I pulled over
It was that mad. I hit it at around 75mph and the gouge in the road was about 1/10mile long. I couldn't see it because it was night time.
Its the old school ugly weights (16" winter wheels + tires) so I doubt one feel off. I'll check to see though.
yeah maybe its just the alignment, the steering wheels doesn't really pull at all.
Last edited by rallyracer; Feb 28, 2010 at 02:20 PM. Reason: Automerged Doublepost
Did you control arm look bent or anything that you could visually see? I don't see anything odd about mine.
Last edited by rallyracer; Feb 28, 2010 at 04:31 PM. Reason: Automerged Doublepost
it was the way the light was catching it. it looked like it had a crack in it. how do all your links and everything look? nothing visually looks wrong..... mighta just knocked the alignment out or over compressed the strut idk.
Not a huge noticable difference. But I would go to the driver side and be able to fit 3 fingers between the tire and fender, where as i could only fit 2 on the passenger side.
yeah I'll be installing Pedders, TC struts and shock, OTTP Stage 1 mount, Pedders rack spacer (once I can get a hold of some) and such... Alignment will follow soon after.
Install will be in about a month or so, so I hope she can hold out
Are you coming alone? You can room up with People and that brings the cost way down. Worst case I can get another room...The MN crew will already have 2-3 rooms with people sleeping in the beds, floor, shower, ect...
-Hotel-
Hampton Inn
2061 Shell Drive
Libertyville, Illinois 60048
(847)680-8828
Rooms are held under "create engine depot"
Be sure to specify whether you want 1 king or 2 queen beds.
Here's some of the info I have organized for the MN group.
https://www.cobaltss.net/forums/north-central-106/minnesota-2010-ced-meet-chat-203947/
Last edited by rallyracer; Feb 28, 2010 at 09:31 PM. Reason: Automerged Doublepost
