How to Rear Brake Job?
Old Jan 22, 2008 | 08:40 PM
ikeryder13's Avatar
I just wanted to see if anyone had done a how to for the rear brakes...?
Old Jan 22, 2008 | 08:42 PM
D4u2s0t's Avatar
disc or drum?
Old Jan 22, 2008 | 08:44 PM
boostedss26's Avatar
If someone dont know how to do a brake job on either drum or disk you shouldnt be messin with a car
Old Jan 22, 2008 | 08:45 PM
D4u2s0t's Avatar
that's a dick thing to say. everyone has to learn at some time, and it's not hard to do.
Old Jan 22, 2008 | 08:48 PM
Sorry i wasnt tryin to be a dick
ikeryder13's Avatar
Well if someone can tell me it will be very well appericiated
Old Jan 22, 2008 | 08:49 PM
What are you looking for disk or drum?
Old Jan 22, 2008 | 08:50 PM
hawlyns711's Avatar
i had no idea how to do it, but i looked at some how-to's and it went fine i had no problems.
if they're rear disc, take off the caliper and you need to use the tool that "screws" in the rear pistons in the calipers (or use needle nose) to fit the new disc inside the new pads, then put caliper back on the car. pm me if u need help
and i saw u had a ss/sc in your PROFILE so he has rear discs
Old Jan 22, 2008 | 08:51 PM
D4u2s0t's Avatar
i asked if you need disc or drum. what model car do you have
Old Jan 22, 2008 | 08:53 PM
ikeryder13's Avatar
disc brakes,i have a 07 ss/sc
JRelly's Avatar
He has an SS/SC
Old Jan 22, 2008 | 08:54 PM
D4u2s0t's Avatar
o, piece of cake then. jack the car, take off the wheel, and you have to loosen ONE bolt. then the caliper will slide up (still connected by the other bolt) then it's as easy as popping the old ones out, putting the new in. you can follow a how to for the fornt, same thing
Old Jan 22, 2008 | 08:55 PM
ikeryder13's Avatar
what do i use to compress the caliper piston?
or screw it in?
Last edited by ikeryder13; Jan 22, 2008 at 08:55 PM. Reason: Automerged Doublepost
Old Jan 22, 2008 | 08:56 PM
if you don't have a piston compressor i use a bigger c clamp. only pust on the piston thought not the pad
outtamymind's Avatar
if you have a C-clamp those are the tool of choice.
Old Jan 22, 2008 | 08:57 PM
ikeryder13's Avatar
i thought it has to be screwed in?
Old Jan 22, 2008 | 08:58 PM
What had to be screwed in the piston?
hawlyns711's Avatar
or screw it in?
the fronts will press in (i used a c-clamp, easy enough) and for the rear you need to screw in, you can use needle nose pliers (you will see how to screw in when it's off) or you can rent the tool from autozone. you need to screw it in to fit the disc between the pads
All the piston is in a sense is a hydrollic ram it just pushes right in. kinda stiff thats where the c-clam comes in
Old Jan 22, 2008 | 08:59 PM
ikeryder13's Avatar
thats the problem i had and i didnt know there was a tool... DO u know what its called?
hawlyns711's Avatar
only the fronts push in my friend, the tool is a cube that uses 3/8" socket to screw in
Old Jan 22, 2008 | 09:01 PM
oops my negative. Never did rears on my car. Plenty on other vehicles. I feel like a real tool
Old Jan 22, 2008 | 09:02 PM
hawlyns711's Avatar
here is the tool you need
disc brake piston cube
http://www.toolking.com/products/586...lebase=OTC4589
autozone rents them i know for sure
ikeryder13's Avatar
so can u use just the 3/8" socket? Does it have a name?
Old Jan 22, 2008 | 09:04 PM
hawlyns711's Avatar
haha 3/8" socket WRENCH (not the actual socket). you shouldn't have a problem
