HRR Rubbing inside wheel well, help!
Old May 27, 2013 | 11:37 AM
bigturbohhr's Avatar
so yeah dumped the front (With lock rings still in) i wasnt rubbing on the fender but instead it was rubbing the wheel well, dont know if cobalts have the same issue but here is a picture.
if anyone has any suggestions other then tubbing my ears are open!
Old May 27, 2013 | 11:43 AM
jmesl8er's Avatar
Take a heat gun and massage it out.
Old May 27, 2013 | 11:46 AM
Omnigear's Avatar
raise car up...
Old May 27, 2013 | 12:39 PM
^ LOL higher is not an option! and yeah im gonna try to heat it, i dont think a heat gun is hot enough!
Old May 27, 2013 | 12:46 PM
turbosmart4's Avatar
Cut a hole there lol
Old May 27, 2013 | 12:48 PM
SalvageBaltSS's Avatar
heat it up with a torch , then take a hammer to it!
Old May 27, 2013 | 12:49 PM
^sketchy much? lol thanks for the tip!
Old May 27, 2013 | 12:52 PM
lol its not man, your car isnt stock so it doesnt matter. out here in the sticks we do jeep cherokee's with lifts. and thats what we do when the bigger tires scrub a little bit lol after you hammer it, you can also take a body hammer to it, and make it nice and curved, so it looks somewhat decent.
edit: it just looks like it need like 0.50 of a inch dented in.
Old May 27, 2013 | 12:54 PM
i ment sketchy by cutting a hole where it rubs, i think im gonna go somewhere with a cetlyn torch to get it nice and hot and maybe use an air hammer.
Old May 27, 2013 | 12:56 PM
oh lol. well goodluck. keep us updated
Old May 27, 2013 | 12:59 PM
will do
Old May 27, 2013 | 01:11 PM
Omiotek's Avatar
raise it up till it doesnt rub.... your on coilovers its an option for you. smaller tires? does look like its rubbing all that bad so i cant see raising it slightly making a big deal.
are those stance coilovers? looks like the preloads maxed as well. change it.
if you have to have the thing slammed so low that your rubbing like that heat it up , bang it in repaint your bay because all the heats going to destroy whatevers in that area(especially if you use an oxy torch) unless its moved. at minimum it will destroy the paint and undercoating. at the end of the day its your car do what you please.
Old May 27, 2013 | 01:15 PM
omni, yeah preload is maxed, why wouldnt i want it maxed. i though max preload makes them stiff.
Old May 27, 2013 | 01:16 PM
Powell Race Parts's Avatar
^^^ nope.
Old May 27, 2013 | 01:23 PM
yes, more preload gives u a stiffer spring, it also reduces travel which i know your not a fan off.
Old May 27, 2013 | 02:10 PM
Omiotek's Avatar
it reduces travel it does not make it stiffer. valving inside the shock and the choice of spring is what does that. the preload basically controls the drop and compression of the spring not the load(stiffness)
More preload = less droop travel, and more bump travel (because of a higher static ride height)
Less preload = more droop travel, and less bump travel (because of a lower static ride height).
none the less. raise the car up a little bit. its honestly not rubbing that bad based off the pic. what size wheels and tires do you run?
Old May 27, 2013 | 02:19 PM
yeah my first comment to you was a tad on the sarcastic side, i raised it a 1/4inch. im running a 225/45/18 on an 8 inch rim.
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
grampss
Sep 27, 2015 08:51 PM
