I need help immedialty!
Old Aug 18, 2011 | 03:25 PM
Supabalt's Avatar
Im putting eibach sportlines up front and im having problems. How do i get tthe sway bar to dicconnnet. weve losened it but it wont give. also the 2 nuts for the spindle have been taken off but we cant get the bolt to slide out. I need help fast please
Old Aug 18, 2011 | 03:27 PM
F_Imports_09tc's Avatar
? There are multiple write ups for spring installation. Sounds like you're doing it wrong.
Search is your friend
Old Aug 18, 2011 | 03:28 PM
BumbleBee's Avatar
follow this exactly, you couldn't get a more perfect write up than this.
https://www.cobaltss.net/forums/how-...springs-50477/
Old Aug 18, 2011 | 03:29 PM
Supabalt's Avatar
Im following those, the bolts are like stuck in the spindle and the sway bar
Old Aug 18, 2011 | 03:31 PM
dannysauer's Avatar
Wd-40 and a hammer but put the nut back on then tap them out
ford's Avatar
Try relieving pressure on the spindle to release the bolts, its possible you have tension on them preventing you from taking the bolt out.
Then again, provide pictures of where you are at so i can make sure you arent about to kill yourself.
Impact
/thread
Old Aug 18, 2011 | 03:32 PM
07BoostedG5's Avatar
x2 impact
Old Aug 18, 2011 | 03:33 PM
Supabalt's Avatar
Pictures will be posted
Old Aug 18, 2011 | 03:37 PM
ooo the strut to knuckle bolts, put the nut back on just enough for the inside of the nut to be covered in thread,and take a hammer to it....The bolts ends have a spline, make sure to mark with a sharpie the realtionship between the bolt end to hub so you not make new cuts in the spline when reinstalling ....good luck
Old Aug 18, 2011 | 03:39 PM
I have done this a million times lol pm if you need further help and you can give me a call
Old Aug 18, 2011 | 03:52 PM
ford's Avatar
Or like i did and dont bother with the nut and just have a rubber 5lb mallet and 4 hits and done.
Old Aug 18, 2011 | 03:59 PM
that works too! any way as long as you dont mushroom/damage the threads
Old Aug 18, 2011 | 04:01 PM
chris88z24's Avatar
The swaybar link is probably rusted and the bolt stripped. I can almost guarantee that the issue if you drove your car in the winter. Go to Advance and pick up a set of MOOG endlinks and cut the bolts to the old one. What's happening is the bolt is spinning with the nut because the OEM ones SUCK.
Old Aug 18, 2011 | 06:21 PM
ford's Avatar
Rubber mallet doesnt cause any damage
Old Aug 18, 2011 | 06:36 PM
mkulrey13's Avatar
I usually use vice grips and a 18v impact. Works good. Never heard of this MOOG endlinks. Ima look into thoses
EDIT: Did you mean MOOG Tie-Rod Ends?
Old Aug 18, 2011 | 06:40 PM
ctn2mb's Avatar
for the front sway bar endlink u need to use a wrench in the middle of the bolt to hold it from spinning. unless its stripped out like the last guy said.
