INGALLS Engine Damper install.
I finally installed mine last night. What was supposed to be a 30 min installation turned into 4 hours! The reason. No tools. I had to run around everywhere looking for tools. I finished at about 12 pm. I didn't think it was going to make this much of a difference, but the car feels like a sports car should feel. Almost no wheel hop, even with out adjusting it. I'm going to the track this Friday and I will finally be able to get the water out of my tires before my run.
By the way. I'm not entirely sure I did a great job of installing it, because of the lack of tools and having the flu. Are there any signs that I should look for to let me know that I messed up on the install and have to fix it. Thanks to Wal-Mart for their great return policies.
Look for bent brackets. When you are adjusting it make sure that you adjust the daming and the length at the same time.
I.E. - If you adjust the damping tighter the length will get shorter, so you have to adjust the length longer.
I had best luck by unbolting one side from the brackets, adjusting the damping to where I wanted it(11.5 mills I believe), then adjusting the legth to where it lined up with the hole on the braket perfectly.
Also make sure the brackets are parellel and true.
I followed the instructions for adjusting in the "how to" thread... I didn't really move it much from factory settings... so I still get a little wheel hop... but none of this bad "jumping" that it used to do.
this damper will be cheaper, but if the motor mounts yeild more of a result ill spend the cash and get them first even tho in the end its all just pieces to the puzzle
patooyee
Oct 1, 2015 01:07 PM
DANRICKARD
Oct 1, 2015 12:08 AM
