installing coilovers!
Old Apr 10, 2012 | 12:50 AM
T CUPP's Avatar
i am installing my kw v2 coilovers tomorrow. Anyone have any tips or advice that will make the process easier?
Old Apr 10, 2012 | 12:54 AM
dakotaspeir's Avatar
#cobalthoes
Its pretty easy. 2 bolts on the bottom.One tricky one that involves holding a pair of vice grips on the back of it. 3 up top. Unhook brake cable put new on in repeat for the fronts.. and the rears are like 2 bolts. Should have it done in an hour and a half tops.
Old Apr 10, 2012 | 01:15 AM
08ssedan's Avatar
Biggest thing is just remember to jack up the whole rear of the car and undo both shocks. Otherwise its pretty straight forward
Old Apr 10, 2012 | 09:24 AM
T CUPP's Avatar
okay thanks!
Old Apr 10, 2012 | 01:01 PM
T CUPP's Avatar
i cant seem to get the bump stop on the back spring. any tips?
Old Apr 10, 2012 | 01:32 PM
T CUPP's Avatar
nvm i figured it out. next question is the stock bolts will not go in the new rear shocks. Seems like the bolts are too big for the new shocks.
Old Apr 10, 2012 | 03:52 PM
T CUPP's Avatar
Old Apr 10, 2012 | 03:54 PM
sjc0013's Avatar
Window Licker
Dont know if you saw this or not, but it may help
https://www.cobaltss.net/forums/how-...et-beer-65640/
Old Apr 10, 2012 | 03:59 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you sure you don't have the shocks upside down?
Old Apr 10, 2012 | 05:02 PM
T CUPP's Avatar
im pretty sure. isnt the big fat bolt for the bottom of the shock. the top bolt on the shock is too small for the stock bolt to fit it. i am at a stand still with it.
Old Apr 12, 2012 | 12:58 PM
T CUPP's Avatar
the hole will not fit the 7/16 bolt in the bushing so i just used the stock til i can figure out what to do... I called kw and he said use a mic to measure the exact hole measurement on the shock and they might be able to fix it. What is a mic
Old Apr 12, 2012 | 01:17 PM
wtf werent these just for sale?
Old Apr 12, 2012 | 01:53 PM
blackjack232's Avatar
micrometer. AutoZone or Canadian tire. really cheap when on sale
Old Apr 12, 2012 | 02:06 PM
T CUPP's Avatar
yes for the exact reason that the shocks would not fit....
Old Apr 12, 2012 | 08:44 PM
T CUPP's Avatar
will rack spacers fix this........
Old Apr 12, 2012 | 08:59 PM
T CUPP's Avatar
Bump!
Old Apr 12, 2012 | 09:07 PM
BLAZIN07SS's Avatar
I'm too JDM for you
I don't know why you keep asking about rack spacers. Rack spacers aren't going to fix your demolished axle
Old Apr 13, 2012 | 12:57 AM
T CUPP's Avatar
Then what needs to be done
Old Apr 13, 2012 | 01:27 AM
znew's Avatar
wow need new axels for sure
Old Apr 13, 2012 | 11:08 AM
T CUPP's Avatar
well is that all ill need? or more stuff?
Old Apr 13, 2012 | 11:51 AM
T CUPP's Avatar
what could have caused that? the passenger side is fine
Old Apr 13, 2012 | 02:24 PM
T CUPP's Avatar
i took everything off to get the axle off but i cant get the axle to come out of the trans... any tips?
Old Apr 13, 2012 | 02:37 PM
T CUPP's Avatar
nvm got the axle out... idk if the axle acutally broke just the rubber bot around the axle had a hole in it that threw oil everywhere.
Old Apr 13, 2012 | 02:45 PM
Wangspeed's Avatar
Are you sure you don't have the new shocks upside down? Plenty of people have installed these w/o an issue.
Old Apr 13, 2012 | 04:17 PM
T CUPP's Avatar
no i talked to kw and had a mic measurement and the top bolt measured .380 and its suppose to be a .412 i think.
