Koni's VS Stance
Old Mar 15, 2011 | 06:02 AM
flyy's Avatar
Koni's VS Stance
Okay so I have an LS stock shocks/struts (fe1's) I also have sportlines on the fe1's. I want to lower the car even further. How much lower would I get with Koni's & sportlines over my fe1's & sportlines?
If It's not a great deal lower like 1.5+ in' then I'm debating on just buying stances and calling it a day.
What do you guys say?
Old Mar 15, 2011 | 03:15 PM
dandaman15's Avatar
It wont be any lower, either get lower springs or get the coilovers. Thats your only real choice.
Old Mar 15, 2011 | 03:39 PM
LS6Rally's Avatar
^ what this guy said.
Shocks,Struts Dampen Spring movement, they in no way affect ride height
Old Mar 15, 2011 | 05:10 PM
Wangspeed's Avatar
Konis might not lower it, but they have excellent valving properties. I have a dyno chart of the rears comparing the Konis and stock FE5. Still waiting on the front graphs. Will share when I've got both.
If you've ever seen a Stance shock dyno, they are nothing special, and are kind of lacking, IMO. Combine this with other non-street friendly issues, like lack of travel, and it's a no brainer for me. Koni or FE5 struts and shocks.
Old Mar 15, 2011 | 05:13 PM
whyyoumadson?'s Avatar
What wangspeed said.....pedders are the best spring atm but there's room for improvement
Old Mar 16, 2011 | 03:25 AM
flyy's Avatar
so koni's and pedders it is
Old Mar 16, 2011 | 03:29 AM
thedude411's Avatar
pedders will raise your car from which its at. that goes against your whole "i wanna go even lower" mentality
Old Mar 16, 2011 | 07:37 AM
flyy's Avatar
so then WTF is the point ARGG, im sure that stances would give a lot stiffer ride than what im on now though right?
Old Mar 16, 2011 | 08:15 AM
they lower the car they just dont get it real low......
Old Mar 16, 2011 | 08:17 AM
are you looking to go on the raod coarse or autox this car? if you are dont waste the money on the stances. they are souly a good street coilover and thats it. any company that puts a lesser spring rate in the back then the front is a complete fail when it comes to the design for the cobalt. i had these and went to pedders springs because i was unhappy on the track. the pedders and koni combo or fe5 strut pedders combo will be your best bet.
Old Mar 16, 2011 | 08:26 AM
Zero6LS's Avatar
To the op. U gotta consider daily driving conditions before slamming ur Balt. U don't wanna ride an inch off the ground and Bottom out every where. Another thing, what's the cars intended purpose?? I'm doing fe5 struts and shocks and ssc springs on my LT in a few weeks. Plus I've already got eibach front/ rear sway bars. My car should handle way better then. Just figure out exactly what u want and go from there.
Old Mar 16, 2011 | 08:38 AM
WA9260SS's Avatar
Your on Sportlines and want something with at least another 1.5" or more of drop???
It sounds like the best choice for you is either H&R or B&G Springs, or CO's. Once you get into CO's look at spending easily $1,000 for your basic setup. I went with Stance primarily for their quality and fitment, bolted on in under an hour. Never had the intention of AutoXing my car though.
Old Mar 16, 2011 | 09:53 AM
flyy's Avatar
Yeah im not looking to autoX my car only run it down the track. I just really don't like the look of my car with 17" rims just doesn't seem low enough. Maybe I should just get bigger tires. idk. Still thinking about the stances though. What about pedders coilovers anyone have any idea how low they drop compared to the stances and how's the ride on em?
Old Mar 16, 2011 | 09:55 AM
BLAZIN07SS's Avatar
I'm too JDM for you
if you want low, go with stances /thread
Old Mar 16, 2011 | 09:58 AM
Zero6LS's Avatar
It sounds more like ur going for looks more than function. I've got ksport lowering springs and they dropped my LT 2" in the front and like 2.5" in the back. Sits real low now but almost too low for the winter and speed bumps
Old Mar 16, 2011 | 10:19 AM
Stance coilovers are for you then.......they will get you real low and will be ok for the drag stripp. Stances provide the lowest ride height for coilovers....the pedders coilovers are made by bc im pretty sure but are branded differently and have color changes. Junk imo
Old Mar 16, 2011 | 11:32 AM
quikdcride's Avatar
where should i buy my strut mounts from? theyre 80 bucks on ced and like 40 bucks everywhere else
whats the difference?
has anyone here ever heard of a strut seat?
Old Mar 16, 2011 | 11:38 AM
flyy's Avatar
stances it is then
OrangeCoba
Oct 1, 2015 10:00 PM
soaxin
Sep 26, 2015 08:41 PM
soaxin
Sep 26, 2015 08:39 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
Josh@ottp
Aug 31, 2015 01:16 PM
