lowered and noisy
Old Jun 16, 2007 | 04:11 PM
snowbred's Avatar
lowered and noisy
I got my car lowered today on SSC springs. Everything is great execpt that i get sanoise coming from the front end (passenger and driver sides) when i turn the wheel.. now the tech told me that there would be some noise until the springs settle and as i drive the car more is this true? i've never had a car lowered before so this is new to me! Other than that noise i have no pogo or anything like that
Old Jun 16, 2007 | 05:00 PM
chevysalesman614's Avatar
I've heard that before. But my SSC springs didn't make noise while they settled.
Old Jun 16, 2007 | 05:03 PM
HackAbuse's Avatar
Is it a clunking noise?
Old Jun 16, 2007 | 06:53 PM
snowbred's Avatar
yes sirr.. well it was.. it seems to have gone away now after taking some nice curves off the highway
Old Jun 16, 2007 | 09:05 PM
HackAbuse's Avatar
It is/was probably the bolts on the links that connect the strut to the swaybar. If they're loose it will make your suspension "clunk"
Old Jun 16, 2007 | 11:25 PM
BumbleBeeSS
Guest
Posts: n/a
i got mine dropped to, with sport lines, everytime i go over a bump one the street or some uneven pavement i heard some noise in the back. just wondering what it is? i checked the springs and they seem tight, it didnt do this with my stock ones. wondering if its normal? i know with the sway bars i had put on, the eibach, i heard noises from them because they are ureithan bushings.
Old Jun 17, 2007 | 12:33 AM
cgss's Avatar
i have had no problems with my ssc
Old Jun 17, 2007 | 01:41 AM
snowbred's Avatar
hmm it came back again.. its alot better than it was before though, only one side does it now. its more like a creaking/clunk sound, only when i turn the wheel right. I guess i'll give it a few days before taking it in.
Old Jun 17, 2007 | 01:43 AM
HackAbuse's Avatar
Its probably the swaybar link. Bring it back and have them impact wrench the **** out of it
Old Jun 17, 2007 | 02:36 AM
snowbred's Avatar
what does it look like? i can try to tighten it myself.
Old Jun 17, 2007 | 02:37 AM
HackAbuse's Avatar
Unless you have an impact wrench it wont work. The bolt spins freely so it has to be impacted into being tight, it cant be done with normal hand tools
Old Jun 17, 2007 | 02:41 AM
snowbred's Avatar
Ok. Could this also be the reason why i get a slight shake when turning (either direction) ?
Old Jun 17, 2007 | 02:42 AM
HackAbuse's Avatar
I don't think it would do that, but it could i suppose
Old Jun 17, 2007 | 02:47 AM
snowbred's Avatar
alright.. Thanks for your help hack, i guess i'll have a shop check it out tomorrow and see whats going on.
Old Jun 17, 2007 | 01:01 PM
BumbleBeeSS
Guest
Posts: n/a
yea i gotta have mine re checked tomorrow, just wondering if its cool to drive untill then?
Old Jun 18, 2007 | 01:36 AM
snowbred's Avatar
i decided to give mine a week of driving before taking it back.. the drivers side seems to be settling in pretty well.. passenger side is slowly catching up.. ive been reading on other forums and the noise i describe supposedly are the springs trying to settle in to their seats.. i dont know whether to drive like a grandma till they settle or make some hard turns and what not to see what happens... i took some nice curves the other night and that seemed to help alot.
Old Jun 19, 2007 | 06:24 PM
snowbred's Avatar
i think i figured it what is wrong. The spring seems to be rubbing in the against something in the fender.. towards the top, i wonder if the spring became unseated while driving around the first day... looking at the other side there is no rubbing at all.. i
Old Jun 19, 2007 | 08:54 PM
mkulrey13's Avatar
Check your rear sturts, i had the same problem and it ended up being the strut bolts were extremely loose and my struts almost fell out.
Should of installed them yourself, its easier then a oil change. Check all your bolts.
Old Jun 19, 2007 | 09:22 PM
snowbred's Avatar
This is the front though not the rear.
Old Jun 23, 2007 | 09:58 AM
snowbred's Avatar
well we found the problem. The strut tower was rubbing against the spring, small ridges had formed on the strut tower, i guess when they made the car.. The tech just grinded it down and problem solved
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
