Lowering
Lowering
Hey guys, so i've read a few threads about guys lowering there cars on here with just springs. I want to lower my cobalt a few inches to even it out sort of thing instead of having the back up a bit. But i want to know what do i need to lower my car? Whats the best option? If i just got lowering springs, would that do what i need it to do? If i have to replace the struts, shocks, springs etc... or whatever i wouldn't want to spend that much. Any help would be greats, thanks a lot everyone!
So much bad information, my 2.2 struts havent failed yet and I have the lowest drop available from springs(aside from cutting them), same with JN2 and Preston. I know there are quite a few more but I dont remember them offhand, check the spring pics thread in this section, most people have had no problems.
I am a complete ******* when I drive and I love hard turns. I have fully compressed the shock quite a few times, the only reason it hasnt blown is because I didnt cut the bumpstops like most spring manufacturers tell you to do. Only hits them in hard cornering anyways
I have cut springs w/ factory struts... i have an 08 2.2L coupe... I live in the mountains of VA & my struts are still fine. I drive the car every day 45min both ways (you can tell where im from, i measure distance by time, lol) I know prolly the struts will bust if im hard on it... but i plan to bag it anyway... haha, whatever you do, good luck! Lowering is always a good thing!!!!!
I only have springs, and i havent had an alignment yet to get my struts slotted. Im a pretty hard driver at times too, and Im doing fine so far...although i do plan on getting the alignment, and upgrade my shocks and struts.
get a set of springs, eibach sportlines, HHR, Tenzo's, whatever, and throw them on and your good to go. It will create more stress on your shocks but as long as you dont cut your bumpstops you should get plenty of milage out of them with no problems.
When you cut the bumpstops, you allow the strut to bottom out internally, piston meets end of tube hard, bad things happen - like all the oil in the strut puking out or the rod bending
The bumpstops keep the hard parts inside from meeting in a catastrophic way and will extend your strut life.
Ive got sportlines on my sedan lt (36000 miles). I wasnt happy at all with the ride. To bouncy for my taste. I swapped in used low mile SS/TC STRUTS AND SHOCKS and now it rides as it should. I DID cut the bump stops in the rear....but not the fronts.
bump stops are already on the car, find the how to in spring install and u'll see why they say to cut it, I've been running tenzo's for 20k on stock struts and shocks, I go to crappy roads daily, bad bumpy, and if I go fast enough over some of it I get some air time
i know that but i already cut mine and it seems like that isnt the best idea so i was wondering where i could get new ones.
No clue.... My friend does all my cuttin for me, he picked my car up while i was @ work. So I'm not sure what's goin on back there. He told me a little about it, but i've never seen them so i dont know exactly what was done. The front needs put down a little lower so I'll make sure I'm there this time so I can know what's goin on, hahaha.
Word, well definately LMK, I might just cut my tenzos if possible, I know I can and am going to cut my fronts because right now it is sitting nose high.
