Major front end clunking over bumps!
Old Jul 19, 2009 | 11:54 AM
SkuceGoose's Avatar
http://i5.photobucket.com/albums/y17...e/cobalt01.jpg
http://i5.photobucket.com/albums/y17...e/cobalt02.jpg
To make a long story short ive attched pictures of what i believe the problem is. It seems like control arm bushings from what i gather is a notorious problem with these cars. MY question is, is this something that can be changed out yourself or do you need to bring it to a shop? what have other people done in this situation? From what i also hear the part is quite cheap at the dealership, is polyeurthane a good idea or should i stick with another set of stock ones?
Thanks in advance
Chuck
Old Jul 19, 2009 | 12:00 PM
freakta's Avatar
ive gotta check my wifes car cause hers makes all kinds of niose too
Old Jul 20, 2009 | 03:17 PM
silversmile06's Avatar
I have an 06 2.4L SS with 40,000 and I just put new tires,front rotors,front and rear brakes, and passenger side wheel bearing on this car. I believe my struts are bad because I'm getting rattling noisees every time we hit a little bump. I liked this car when I first got it, but it has become a straight nightmare and a pocket killer when it comes to fixing this car and I do all my work myself. I don't see foreign cars with much trouble at 40,000 miles.
Old Aug 19, 2009 | 06:19 AM
mrsilent13's Avatar
are you sure its that...did you fix it? if not you might want to check your endlinks..as thats the only clunking sound that i get...one of my endlinks...gets loose every once in a while
Old Aug 20, 2009 | 06:54 PM
Maven's Avatar
FE1 cars do have a bit of a history of popping LCA bushings out. New ones are dirt cheap but they need to be pressed in. AVOID poly control arm bushings like the plague they are.
EDIT: those pics definatiely showed popped bushings
Old Aug 23, 2009 | 05:36 PM
TommyP's Avatar
AWD > FWD
Thanks in advance
Chuck
A control arm bushing is exactly what it sounds like. I had to replace them after only 20k miles. mine would knock and clunk over every bump but after I had the dealership replace them under warranty the sound stopped. Now my suspension just squeaks all the time. If I were you I would try to find ones better than stock if you can so you don't have to replace them again.
Old Aug 23, 2009 | 06:33 PM
olivecj's Avatar
I have the same problem I went over a nasty bump last week and now i have a clunking sound I gunna go to the dealership this week.
Old Aug 23, 2009 | 07:17 PM
YSUsteven's Avatar
Had mine give way after 17,000, was told that this is more prone in the colder, snowier climates.
Old Aug 23, 2009 | 07:32 PM
sport08's Avatar
i believe mine were bad when i traded my 2.4L in.
Old Aug 23, 2009 | 07:51 PM
09cobaltsc's Avatar
did anyone lower their cars? cuz it will make that noise for a long while till the struts and the rest of the suspension adjust
Old Aug 23, 2009 | 08:05 PM
tru2nrtt777's Avatar
Mine does it for a mile or 2 after I have had it on a lift or jacked up. Smooth sailing after that.
Old Aug 23, 2009 | 08:09 PM
exiged's Avatar
can you circle it in the picture please for noobs like me?
Solaris99
28
Mar 15, 2017 01:22 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Bohb
Sep 27, 2015 09:11 PM
grampss
Sep 27, 2015 08:51 PM
