Megan vs. Stance vs. Pedders Coilovers
Just looking for opinions on what of the 3 is the better coilover and WHY?
Please dont give me a 1 word answer saying " Stance" or whatever, explain yourself.
The reason im looking at these 3 is because they look so simular in build yet range is price. they have pretty simular spring rates. the only difference i have found is the stance coils are 16way adjustable and they can only be adjusted from the bottom of the shock where as the pedders and megan coils are down through the top of the shock on the pillowball, and are 32way adjustable.
any help would be asom.
here are some pic of all there coils.
Megans
Stance.
Pedders.
Megans
Stance.
Pedders.
pretty much what he said. when he rode in mine they were set to full soft and not lowered all the way. i will say i think the rear springs are soft but they made these coilovers with the intent of having streetability and some raceability in mind. going up to a 6k spring in the rear would be all good.
megans are crap but if your looking for a drog they are cheaper and get the job done.
pedders xa their isnt enough info about them from other people yet to know really.
The difference really comes down to the quality of the strut. Sure megan is 32 way adjustable, but you will not feel every click, and they are made cheaper and will not take as much abuse. However Stance uses a quality strut. There may be less adjustment or "clicks" but you will feel every increment. I dont know enough about Pedders to say anything. In the suspension game 98% of the time you get what you pay for.
Thanks for the input guys. i think im gona go with HSD coilovers. HSD makes Stance coilovers. there pretty much identical minus the springs the stance being progressive and the HSD being linear, and the HSD being green and gold.. the shock and struts look the same too. not to mention i can get the HSD coils local.
also to answer your question about adjustability........what are your goals for your setup? you trying to get a badass handeling setup? are you trying to slam it and call it a day? have you played with coilovers before? are you looking for an easily tuned setup or something more complicated?
they dont but if your using coilovers for what they are intended for then why would you be slamming your car?
I've got Pedders coilovers, if y'all have any questions about them. In fact that pic of them above are mine before I installed them.
I installed them for racing and personal preference, though I must say the look isn't bad at all, and the drop the way they come out of the box is more agressive than Pedders springs (with much more room to drop if that's what you're going for... I just used the height that they came with).
When paired with the OTTP Street Bar, I've gotten 1.00g lateral on all-season tires and on an unprepared road. I'm hopeful to see what happens with sticky tires, different camber settings, etc. It's already stuck to the road very well now.
Thanks for all the input guys.
Basicly im looking for a street set up that i can use at the road course/ drag strip, and still drive home without back problems. i have been doing the occasional road race this year but really into the drag racing scene.
I have had coilover before on my mazda3. they were bc coils. i installed them myself and adjusted the shocks and what not to get the proper ride.
i dont plan on slamming my car so to speak. im looking to drop the car so the top of the fender is flush or a little higher than the top of the tire. i want to keep sum shock travel.
Refering to the HSD coils. from what i understand the proto-type Stance coils are the production HSD coils. this can explain not being able to lower as much as the stance.
O well ill keep shopping around. i have the funds and commited to buy coils, now its a matter of research.
i have megan on my 09T/C, and i love it. the shocks itself can be height adjust which is a plus. and the spring rates are good, 6kg front and rear. its a good setup because FWD should not have front stiff rear soft, this will creates more understeer, if you look at a lot of japanese FWD race car such as the spoon civic, integra, they all have fron front springs softer than rear springs. the dampening adjust is awesome, i have it on street setting, and its pretty comfortable. but hey, its linear rate springs, so its always gonna be stiff. can't do much about that, but i handles real good when i went to arroyo seco raceway road course.
Actually 97% of the coilovers for civics have the front stiffer than the rear. Very few companies choose to do it the other way. The only one I can think of off hand is one of the tein coilovers thats like 14k/22k which is nuts and only for track. Otherwise the most common set-up is 8k/6k. How would I know, Ive only been into the honda scene for 3-4 yrs prior to buying this cobalt.
Sorry to get off topic but nice review, how low do you have them set? Any pics? I kind of wrote them off because I can get Ksport for like $30 more than Megan. Megan does use BC dampeners though.
when i first got it
drop
snow
[/QUOTE]
I don't see why one having a stiffer front vs another is such a big deal to y'all... We've already surpassed one lateral g with neutral handling with coilovers! It's obvious that the ingredients are working and working very well.
No need to get bogged down by the details when the end result already shows that it works. Just sayin'.
thanks for all the responces guys. this is a really tuff choice. getting these coils locally is what i really want i dont want to get hit with all the shipping fees.
im gona talk to one of my suppliers tonght to get an idea for what i can get and for what price.
depends if you awnt a good coilover. megans are crap when you compare them to stance hsd(they make stance) and pedders. save up and dont cheap out.
so im looking to get coilovers but cant judify the 1200-1500 on coils megans seem like decent price at 900 new whats wrong with megan i got to track but not much only drag nothing else im looking to slam my car thats all
OTTP hardcore bar
OTTP CAB/front bushings
Pedders
Nitto NT01 w/ -2.0
Quite frankly, a simple skidpad test tells me very little, and my definition of neutral obviously differs from other folks. I call my setup neutral with a tendency to push in slow corners and extended slow sweepers. It's FWD after all...
OTTP hardcore bar
Pedders
Nitto NT01 w/ -2.0
OTTP hardcore bar
Pedders
Nitto NT01 w/ -2.0
How hard were those CABs to get in?
I've currently got an OTTP street bar and NT05s with -1.0... how do you like your tire/camber combo?
