moog sway bar end links
Old Mar 24, 2014 | 11:32 PM
andrewcarr1993's Avatar
Okay perfect.
Old Mar 25, 2014 | 09:55 AM
tomj77's Avatar
Where can I find the torque specs for all this stuff . Or even better all the cars torque specs for everything. Would be nice to have. But I do need the trans, motor mount and control arm torque specs
Old Mar 25, 2014 | 01:54 PM
LNFTX's Avatar
There are actually torque specs in the package
The children or Haynes manual has a **** ton of torque specs in it although I'm sure they're available online
Old Mar 26, 2014 | 04:10 AM
rokon340's Avatar
here ya go.
http://www.gmheritagecenter.com/docs...let-Cobalt.pdf
it's a big file in pdf has a lot of good info thou.
Old Mar 26, 2014 | 04:33 AM
714ionredline's Avatar
^^^^^Man that is some good info thanks.... just out of curiosity you wouldn't have the link to the same service manual for 08 to 10 cobalt ss would you?
Old Mar 26, 2014 | 03:46 PM
LNFTX's Avatar
Ive been on the site I couldnt find it just lsj
Old Apr 26, 2014 | 08:26 PM
tbos548's Avatar
Originally Posted by sl0wlsj
I'll sell you 2 of them, less than 500 miles on them. $27 shipped.
Still have the links for an fe1 suspension for sale? 11.8 long I think
Old Apr 27, 2014 | 03:19 PM
He's banned.
Old Apr 29, 2015 | 11:31 AM
silver cobalt SS's Avatar
end links
Originally Posted by 08baltls
Shorter links are for FE5 suspensions and the longer are for FE1.
Will the shorter ones work on an FE3 suspension.....is their an anvantage to using the shorter ones..? Or should I find the longer ones..06 cobalt ss 2.4 fe3
Old Apr 29, 2015 | 11:46 AM
toolman's Avatar
I used the shorter ones on my FE3 suspension. I didn't notice any ill effects. I'd have to look up the part number to tell you for sure which ones I installed, but I'm pretty certain they were the shorter ones. I've since changed to an FE5 swaybar.
The use of shorter or longer end links only affects the orientation of the sway bar, and the angle at which the end links twist the sway bar. From what I understand about suspension geometry, you want the links to be parallel with the strut when the wheels are on the ground.
Solaris99
28
Mar 15, 2017 01:22 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
