Need advice on rear strut/sway bar
Old May 8, 2007 | 07:43 PM
ReMz's Avatar
Well, I'm looking into stiffening up the car. I'm already set on stiffening up the rear suspension a bit for auto-x. I've done research into this, so no "search" replies plz.
Basically, I am either going to purchase a Progress rear sway bar or a Bwoody "rear strut brace". I'm no suspension guru... so any input on which one would most likely work better would be great. I know a lot of people are happy with the Progress sway bar.
I'm also open to other opinions not concerning these two products as well.
Old May 8, 2007 | 07:54 PM
mkulrey13's Avatar
do both. you would be unstoppable
Old May 8, 2007 | 08:24 PM
biniecki's Avatar
I have the progress bar and love it. I wish i had made it my first mod. Also like mkulrey13 said you can do both.
Old May 8, 2007 | 08:42 PM
bluebaltjim's Avatar
progress rear sway will be a more noticable difference
Old May 8, 2007 | 09:15 PM
ReMz's Avatar
crossed my mind . not necessary unless i had "unstoppable" funds as well.
Old May 10, 2007 | 12:51 PM
FraGmE's Avatar
I have the Bwoody rear bar. in my opinion it doesn't handle exactly like having a rear sway bar but its pretty good. The bwoody was a good price tho when I got it so it works for me.
Old May 11, 2007 | 07:11 AM
denniss's Avatar
It depends on what you want to do. The sway bar will improve cornering and is just a bolt on. The strut brace is designed to allow you to adjust rear toe to change handling and will require some experimentation to get the best results. It would also help maintain toe under hard cornering even if you left the adjustment neutral. Unless you are racing, I think the sway bar would be a better bang for the buck.
Dennis
Old May 11, 2007 | 01:38 PM
Ric's Avatar
Ric
How difficult is installation for the Progress sway bar?
Old May 12, 2007 | 07:31 AM
denniss's Avatar
Very easy, Four bolts. If your skinny, you probably won't even have to jack the car up.
Dennis
Old May 12, 2007 | 01:34 PM
torrin1234's Avatar
why does no one know about the JPB rear strut tower bar?
I am pretty sure that you can't do both, they look like they use the same mounting points and I could believe that would cause some problems.
http://www.jbodyperformance.com/new/...catName=JP0998
^^ looks damn good to me. If only you didnt have to drill... (Im sure that it would be easy but it isnt a "bolt on" kit exactly.)
Old May 13, 2007 | 07:35 AM
denniss's Avatar
Cobalts don't have a rear strut. There is no strut tower to brace. J bodies use a sold axle and strut while Cobalt use a trailing arm twist beam and a shock absorber. Under extreme conditions reinforcing the rear of the body would help, but most of us will never drive hard enough to need it.
Dennis
Old May 13, 2007 | 05:32 PM
torrin1234's Avatar
the bar from JPB is supposed to act like a rear strut tower bar. I know there are no real mounting points, but it's obvious if you look at the product that it goes where the rear wheels go and drills into the steel in the trunk.
I could see it helping, i mean, if it at least reinforces the progress sway bar you should be able to tell a difference.
Old May 13, 2007 | 10:09 PM
wasntme's Avatar
the bwoody bar is fully adjustable and the only bar you can get a true 4 wheel alighnment with, bwoody FTW!
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
