Need Help!!!!!!!!
Old Feb 6, 2009 | 01:18 PM
cobalt man's Avatar
Question Need Help!!!!!!!!
hey guys i think this is the right section to post this seein its the suspension section but anyway i have a 06 cobalt ls and i want to lower it im rollin on 225/40/18's in the summer and i want prolly a inch wheel gap so what lowering springs should i go with and also how much of a drop to get that inch wheel gap?????
Old Feb 6, 2009 | 02:19 PM
c0ld29's Avatar
ok... your car probably looks like it is a 4x4 right now doesn't it? anyways... I have a simple trick for you to use anytime you have this problem... go to your car, measure the gap between the wheel and fenders, and then subtract and inch. Now that is how much of a drop you want.
After you got that number for the front and rear, look through the different springs drops for your car or use the search tool on diff springs as there is a lot of info about all the diff springs on this site.
Sorry if you wanted an exact "get this spring" answer but I didn't know how long it would take another LS owner on the same size tires as you with springs to respond.
