Need to lower the rear...
So I have my 10 ss which is lowered with h&r springs. Only issue is the back is so much higher than the rear. I would like to lower it more, the only rear springs I found available separate are pedders. Not sure if these will get me lower or not? Also ordered koni rear shocks through my work today so hopefully have them next week sometime.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[IMG]
[IMG]
[IMG]
It looks like you have the H&R Race springs, which do have quite a bit of rake from what I hear. The H&R Sport Springs, which I believe are blue in colour, will even it out quite a bit more (I'm after a set myself). Look for pictures (or have him post in here) of 07MetallicSC's (sp?) car- his sits on H&Rs and he has many pictures around here.
Anybody sell just rear springs? Only thing I have found are pedders, not sure how much they will lower it but may be the only option. I don't want to change the front its fine the way it is.
I've personally seen a 09 SS/TC on the first set of stance coilovers made (were a prototype set) and the car looks great, But I'd still take my Koni's and YYZ V3 springs for the handling.
I'd definitely take the YYZ's instead of coilovers. Coilovers are a PITA on a daily driver in my opinion. It takes a lot of tedious trial and error to get them all even, then changing the stiffness is a whole 'nother demon in itself.
heres a pic of my car with the H&R sport first installed
it looks way lower now. some settling and alot due to weight (see sig)
OP must have the sport NA springs. He needs to get the SS version with the -2 at the end of the part number. My car dropped another inch or so in the rear when I swapped the two sets of H&Rs out.
You can swap out different rear springs. Sportlines or HR sport springs lower the back quite a bit more then what you have. I had a 2 finger wheel gap with sportlines in the rear.
So I would like to swap just the rear springs to drop it down lower. I suppose I will have to call around to see if I can get just a rear set. Only ones I see available are pedders. I don't want to change the front because I like the way it sits already.
