Need some help with swaybar bushings
I've got an 05 SS.. I'm trying to replace my sway bar bushings but I can't get the back of bracket to slide down in groove.. When I go to put bolt in the front it pops out of the groove.. Is there a trick I'm missing? Thanks
Originally Posted by volsfan92
(Post 7575975)
same problem here... did you find what the problem was?
You might have the wrong bushing? Does it close all the way around the bar?
yess indeed, had bought 22mm but I needed 18mm for my car.. so went back to the store and replaced them. Perfect fit.. took only about 10 minutes to replace the other side after that.
