Need Wheel Spacer Sticky
I have been searching all over this site and found that people have ordered wheel spacers but no information to specifics. Please try to answer every question so we can create a more informational sticky. Please post your:
Wheel Spacer Type: Website bought: Thickness: Hub or Wheel Centric? Replaced studs?: What stud length: Lugs Stock or Aftermarket?: Lug Type: Website bought: Rims Stock or Aftermarket?: Offset: Please post a pic with this and I will get a sticky created. Thanks!!!! Reserved Reserved |
Front:
Wheel Spacer Type: 5x110 to 5x110 hub adapter Website bought: ebay Thickness: 1" or 24mm Hub or Wheel Centric? 67.1mm hubcentric Replaced studs?: yes What stud length: autozone/napa studs with no nubs at the end basically Lugs Stock or Aftermarket?: aftermarket Lug Type: type x racing open ended lugs Website bought: summit Rims Stock or Aftermarket?: stock sstc (worked with sc too) Offset:idk Rear Wheel Spacer Type: 5x110 spacer Website bought: ebay Thickness: 12mm or 1/2" Hub or Wheel Centric? Hub centric 67.1mm Replaced studs?: yes What stud length: arp extended studs (from zzp) Lugs Stock or Aftermarket?: same as fronts, aftermarket Lug Type: open ended Website bought: summit Rims Stock or Aftermarket?: stock tc (works on sc too) Offset: idk ARE YOU RUBBIN? - a little in the rear over the right bumps, im lowered 1.5". Oh and on 225/40 tires. Could use a fender rolller |
Ohh subd for sure. Great idea
Crap pic on the sc wheels but it is quite flush.
(Post 7520939)
Thanks for the quick reply Rice. Hope other chime in!!
Hey rice you have a part or anything like that for the napa studs?
Originally Posted by DillySS
(Post 7520945)
(Post 7520947)
AlteredToyz hasn't rolled in a while. The prez moved to Ottawa and the other guys all had babies.
So I've bought all the parts and waiting on the wheel spacers. I will take pics and build this out further once I get everything dropped, spaced and rolling.
Great thread. I need 5mm spacers for my brembos along with hub spacers. How would my front wheels line up with that? Not flush at all huh?
