NEW Eibach Rear Sway Bar
I don't know if anyone has seen the new sway bar, but i had the old gen one and it snapped on me in probably less than 5,000 miles, and now i just got my new one in today that Eibach that they had said they were "Redesigning" for free of course.
It seems to be alot thicker towards the ends where my old one snapped. I just wanna see what you guys have to say about this "new" one, if it looks any better than the last.
Just let me know what you think.
^You can see where it snapped on the left side^
I have yet to put mine in, i just wanted to get some opinions before i put it on, i'll probably throw it on tomorrow to see how it is. I hope it doesn't vibrate cause ill be throwing it right in the trash haha.
I just logged on to post the exact same thing...Same situation too. I had the old one, it snapped after a couple months
Got the new one today and installed it. Got a few pics as well.
The TWB does exactly what the name implies. It twists. Because you put that bar in place, it's essentially turned into a live axle instead. The distance between those two mounting points will change depending on how much the beam is twisted, but because the bar is a fixed length, the beam can't twist properly. There's no point to your swaybar with the tie beam there.
Wangspeed, like usual , is 100% correct. BTW thats a very inefficient way to make a sway bar fit to the beam, it will deflect around the bracket and bolts. oh well.
Warren your parts are shipping today ( at last).
but no money at the moment for it.. im saving up for quality stuff the first time.. i dont wanna learn my lesson the hardway anymore
I honestly prolly will grab the hardcore bar eventually. This bar was free under warrenty, so no harm no foul right now. And does the tie bar really screw up the rear suspension that bad? Is there any way to get any advantage out of it?
BTW, agita_san, your driver's side rear shock bolt isn't tightened all the way down. Dunno if this was just loosened as part of the install or what.
Oops, ignore that. I guess it is. Was hard to see, but I'm looking at the metal sleeve, not the bolt.
