OEM Brembo pad wear
Old Aug 2, 2011 | 01:06 PM
RHZ's Avatar
RHZ
OEM Brembo pad wear
So I have about 44K miles on my OEM brembo pads with stock rotors- likewise on the rear. Just ordered new OEM pads from CED- just curious as to how many miles other people are getting on these pads? I'm starting to get some noise(slight grind) from the front driver side when i brake- i've never ever heard the front squeak.
P.s. i normally engine brake whenever i can to save the brakes but i think it's time to replace.
Old Aug 2, 2011 | 02:15 PM
Gremlin85's Avatar
I've got close to 42k on my stock front OEM Brembo pads and there is plenty of meat left on them. I'd say they are about 50% - 60% worn. The rotors, on the other hand, are pretty worn. There is a nice lip from the pads actually wearng away the rotors pretty quickly.
Old Aug 2, 2011 | 02:16 PM
Sweetsandman's Avatar
The OEM pads are very aggressive pads. They are Ferodo (spelling?) pads, not Brembo pads. You're not going to see long life out of those pads like you would with say some Hawks or some cheap Duralast pads, but in terms of braking performance and fade resistance, they are pretty much unmatched.
Old Aug 2, 2011 | 03:00 PM
HmF300ex's Avatar
20k and my front driver is squeaking, both are worn down and rotors are severely grooved. rears are going to need replacement soon too. car got raped by the prior owner though
Old Aug 2, 2011 | 03:11 PM
cmcphi1195's Avatar
I'm at 38k with about 30% left. My rotor is pretty screwed though
Old Aug 2, 2011 | 08:20 PM
Sox-Fan's Avatar
Got Brakes?
38k, rotors are fine, pads look like they'll go a ways. Rears are all good, though the rotors and pads back there were replaced at 13k, or 17k, I forgot which. They'll occasionally squeal in the morning the first time I use them but not always. Once they're warmed they make no noise at all.
Old Aug 8, 2011 | 03:59 PM
RHZ's Avatar
RHZ
Just got my new pads in the mail. I'll take some pics of my old pads when i get around to swapping.
Old Aug 12, 2011 | 10:49 AM
RHZ's Avatar
RHZ
Turns out my brembo pads are fine and look to have 40-50% life left in them. My rear pads on the other hand were completely shot. They were totally unevenly worn- the outer pad was at about 60% and the inner pad was down to the metal. Replaced the rears with OEM pads from CED and car is running like a champ again. Lubed the snot out of the pins and going to make sure i do it several more times a year.
Old Jan 19, 2023 | 12:41 PM
chevy2's Avatar
Old thread revival for new piece of data-?
Does anyone have the OEM Ferodo pad thickness measurement for when they are new ('09 SS/TC Brembo front brakes)? Total thickness including the backing plate is fine- I have a set on the car (duh) and I can measure the plate thickness and subtract to get the pad thickness when new, so I can figure out how much "life" is left on my pads.
It's interesting to read the above estimates of wear and life left, but no note of the dimensions.
Thanks for help .
Jan 12, 2016 12:01 AM
2009blackSS
Sep 30, 2015 05:57 PM
Trav3480
Sep 28, 2015 02:46 PM
grampss
Sep 27, 2015 08:51 PM
jas09ss
Sep 26, 2015 01:06 PM
