officially voided my brake warranty...
took my car to the dealer again yesterday about my paint chipping and my brakes shuddering for the 2nd time in 4 months. they looked at my tires and said they were getting bald in the middle which is from excess speeds and my brakes turned blue or something which is from too much heat meaning that im driving the car too hard. they fixed my brakes this 1 last time by shaving them down but said they wont do it a 3rd time. well in my opinon i dont drive the car that hard on a daily basis and i think the brakes just arnt well suited to the car or they are defective. so now i guess when it starts happening again im gonna have to fully upgrade my brake system which will probably cost upwards of $500. on a side note they didnt even fix my paint on my trunk that was chipping they just touched it up and i can still tell the chip was there...
Any paint issues where the paint is peeling (not chips but actually coming off the grey primer underneath) and the dealer should be repainting the entire part.
Bald in the middle is over inflation which *might* be possible from too high a speed for to long a time, but is more than likely from over inflation.
The blue color from overheating can also happen from slowing down suddenly after a prolonged high speed run (talking hour+ here) which can then cause the very hot rotor to warp. My Cavalier did this.
I do not know about the front but the rear brakes for sure are not suited to the car. 10" by 0.55" on this car is way too small. I went for a big brake kit front and rear right from the start to avoid this.
- Solo
- Solo
You guys beat me to it on the overinflation thing.
As for the brakes, it's mostly been mentioned...slowing too quickly, lots of hard braking, dragging the brakes for a very prolonged period, and setting the e-brake when your rotors are too hot can also cause warping.
well, if i put on ebc brake pads, which ones should i get? im thinking the green pads for street use, but if im heating them up so bad then maybe the track red pads would be more suited to me? or is this not the pads fault and i would need to get slotted rotors? if i do both of those things im gonna just throw some stainless steel lines on there as well to finish it off.
Guys the brakes on this car are excellent, they are by no means to small for a car that weighs less than 3000lbs.
My 2003 Mustang GT had smaller brakes F/R, my LT1's had smaller brakes.
Improper lug nut torque warped my rotors, hell from the factory some were at 40ftlbs others at 110ftlbs.
I am not saying this about you directly celicacobalt but most brakes get burned up or warped due to really smart people going way to fast then hitting the brakes.
If you must go really fast leave enough room to slow down.
Originally Posted by celicacobalt
my tires were at 50 psi for a while since i was not aware that the psi stated on the tire was not correct, they are now at 30 psi
Originally Posted by bluedev1l
It probably says 50 PSI MAX on the tires.
If it was from high speeds, the tires would be pressed harder against the ground making them wear the outsides of the tire as it were under inflated. The SS S/C manual says to raise the PSI from 32 to 35 if driving for extended periods at 100+ mph.
Talk to Uneek about a set of cross drilled and slotted rotors and a set of pads. ExHondaMan bought a set and they have worn much better than the stock rotors.
Here's some rotors for the 5x110 bolt pattern. He also has pads. Will not fit the ss.
Just look at the bottom of the page.
http://www.socalhhr.citymax.com/products.html
well, i have driven all of my other cars like this and never ran into this problem, on my celica i had TRD brake pads and stock rotors for a year and a half under the same driving conditions, so i think the stock brakes suck alot to have been giving me problems at 500 miles
I just think people confuse parts quality vs brake system quality.
The braking system is excellent and stops the SS/SC with ease and in very short distances. But the materials used in the manufacturing of the rotors could have been better.
As for the brake pads they are nice but seem to be way to hard.
yeah i can agree with you on that so i guess new parts will be coming after these brakes are totally worn out, hopefully for about $500 i can get ebc pads, slotted rotors and ss brake lines all at once
i spoke to a gentleman for a set of rotors and i want to say he quoted me like 250 for the works cross dilled, slotted, and cryo treated, plust the pads themselvs, but im not sure if it was a "deal" or not what yall think?
