OTTP Spherical control arm bushings??
Old Nov 27, 2009 | 11:00 PM
05RLS2's Avatar
I have been thinking of doing the spherical control arm bushings to maybe improve handling a little. Right now, my suspension is stcok for the most part. Will dropping in the spherical bushings make much of an improvement, or are they intended for a much more upgraded suspension? Do these change the ride quality at all?
On the site it says that they are designed for the FE5 control arms. I am guessing that is SS TC only, correct? If so, looks like I'd have to buy control arms also. What do you all think, are the spherical bushings really worth dropping about $300 on for the bushings and control arms for the performance improvements they offer?
Old Nov 27, 2009 | 11:01 PM
slowswap's Avatar
The bushings fit SS/NA, SS/SC and SS/TC control arms. In other words, any of the aluminum control arms.
Steering response will be improved.
Old Nov 27, 2009 | 11:05 PM
ls1fbody's Avatar
Haz l33t wheelz.
i wasn't aware the FE3 suspension had aluminum CA's? The bushings also help to fight wheel hop.
Old Nov 27, 2009 | 11:09 PM
slowswap's Avatar
Yes sir.
Old Nov 27, 2009 | 11:12 PM
ls1fbody's Avatar
Haz l33t wheelz.
Well by golly. they do. That's good news.
05RLS2's Avatar
Ugh, looks like I will have to get FE5 control arms if I were to get them.
Are the FE5 control arms a direct replacment for those on a FE3? Will anything else need to be changed out when doing so?
Old Nov 27, 2009 | 11:14 PM
slowswap's Avatar
If you have FE3 suspension you have the right arms. Or did you mean FE1?
What car and model do you have?
ls1fbody's Avatar
Haz l33t wheelz.
nothing needs to be changed. If you have cast aluminum arms, you can use the bushings. If you have stamped steel, you have FE1. What trim level cobalt do you have?
Old Nov 27, 2009 | 11:25 PM
05RLS2's Avatar
Ion Redline
It has the FE3 suspension, but I am not for sure I GM used a different control arm for the SS or if they are the same
Old Nov 27, 2009 | 11:32 PM
ls1fbody's Avatar
Haz l33t wheelz.
look under the car, haha, are they silver or black?
Old Nov 27, 2009 | 11:34 PM
Caligula's Avatar
This is news to me, anyone have a link to these?
Old Nov 27, 2009 | 11:35 PM
05RLS2's Avatar
I will have to take a look at them
Silver = good for bushings, and black = replace with FE5, correct?
Old Nov 27, 2009 | 11:37 PM
ls1fbody's Avatar
Haz l33t wheelz.
http://www.ottperformance.com/store/...l-Arms-c41.htm
correct.
Old Nov 28, 2009 | 12:10 AM
87gn06gto07irl's Avatar
Ion Redline
they will not work for us. we need to get ss arms.
Old Nov 28, 2009 | 02:38 AM
05RLS2's Avatar
That sucks. I guess I'll hold off for now on this and do it all at once when I start upgrading to the FE5 swaybar, sturts, and shocks
Old Nov 28, 2009 | 02:56 AM
Caligula's Avatar
Thanks for the link, OTTP has some amazing deals.
Old Nov 28, 2009 | 07:30 PM
alredline04's Avatar
You can find Fe5 control arms all day salvage for around $45-$100. Check out car-part.com. Just make sure you look up the arm for the Cobalt. As you already may know the RL Fe3's are steel.
Old Nov 28, 2009 | 07:47 PM
phatnackySS's Avatar
have you looked at the chrome moly LCA zzp is in the prosscess of testing, maybe worth looking into.
http://www.zzperformance.com/cobalt_...new1.php?id=57
the set they sell for the grand prix is about 500 bucks so the bushings are cheaper...
Old Nov 28, 2009 | 08:53 PM
northvibe's Avatar
ehhhh I would say its hard to recommend the zzp ones.
1. the ottp cabs are from the time attack SC/SS. tried and tested on a track car...and pushed hard.
2. the stock control arm is one hell of a solid piece.
3. testing on the zzp piece probably isnt as extensive as the ottp.
4. theres going to be more stress points on the zzp since its tubular and welded, the stock arm is all solid, but chromoly is strong.
Old Nov 28, 2009 | 09:14 PM
qwikredline's Avatar
agreed ;the biggest issue of all (#5) spherical joints are not weatherproof...thats a problem...and poly makes a lousy joint for the leading bushing... the OTTP ones are different...
Old Nov 28, 2009 | 09:16 PM
ls1fbody's Avatar
Haz l33t wheelz.
From ZZP's site: "Pair sheds 5 pounds of weight"
I don't know how you would save 5lbs off the stock arms. Maybe the stamped steel, but the cast aluminum can't weigh anymore than 5lbs each.
Old Nov 28, 2009 | 10:14 PM
tru2nrtt777's Avatar
The weights are somewhere on here, the LS arms weighed 2.2 lbs more than the SS counterparts.
Old Nov 28, 2009 | 10:39 PM
Valid points, just throwing it out there ,Im actully looking into the LCA busshing, im running my traction bars for now, but i have to keep them lubed after it rains and what not, plus some people say traction bars tend to fail (out of rond eylets) with extended use on daily driven cars. is that price for 2 or just one , if its for the pair , then its not a bad deal at all.
Old Nov 28, 2009 | 11:35 PM
northvibe's Avatar
yeah blackfriday sale was $150 a pair so I bought them hahah
Old Nov 29, 2009 | 02:32 AM
slowswap's Avatar
Chromoly is also more britle.
