Pedder Spring concerns
Old Nov 3, 2011 | 06:08 PM
EcotecRacer's Avatar
which you want measurements between?
Old Nov 3, 2011 | 06:19 PM
C_A_D88's Avatar
Pedders are over rated it could be a spring issue
My rears were 50 lbs off from one side
To the other, compression tested by John powell
Old Nov 3, 2011 | 06:21 PM
C_A_D88's Avatar
Doesn't look like theres
Anything wrong with the struts, one
Is just sitting on the ground higher then the other
Old Nov 3, 2011 | 06:27 PM
after measuring between those 3 lines i see no difference at all
like mentioned it must be angle they are sitting/laying on ground
Old Nov 3, 2011 | 06:28 PM
Sox-Fan's Avatar
Got Brakes?
I don't see how that could possible happen if *both* press fit bolts are in the right holes.
Old Nov 3, 2011 | 06:29 PM
SKCobalt's Avatar
I would measure between your top and bottom lines.
Old Nov 3, 2011 | 06:51 PM
asanti's Avatar
That's weird for sure. I do have a slight amount of negative camber in the front with the Pedders (HHR SS here also), but nothing crazy. That gap difference throws me for a loop... I'll check mine to see if there are any differences in mine just to see if I can be any help to you.
EDIT: here's a pic of mine; you can see how little neg. camber there is up front. AFAIK that's normal with a Pedders drop, any more than that there may be a suspension issue???
Later
Allex
Old Nov 3, 2011 | 06:59 PM
Later
Allex
that would be of great help since same kit and same vehicle! very much appreciated
could you take any of the strut to tire gap by chance?
Last edited by EcotecRacer; Nov 3, 2011 at 06:59 PM. Reason: Automerged Doublepost
Old Nov 3, 2011 | 07:04 PM
asanti's Avatar
I'll try to shoot a few pics tonight once I get home from work.
Later
Allex
Old Nov 3, 2011 | 08:29 PM
YelloEye's Avatar
Am I the only one wondering why your HHR has 2 passenger side struts?
Old Nov 3, 2011 | 08:32 PM
  #36
Dart_SI's Avatar
Bingo. I knew something was peculiar.
Old Nov 3, 2011 | 08:34 PM
  #37
elecblue06's Avatar
nope i as soon as he said they're the same part number i was like well theres your problem lol the passenger and driver PNs are different
Old Nov 3, 2011 | 09:06 PM
  #38
YelloEye's Avatar
AC Delco numbers for left and right are:
Drivers side: 560-581 (RockAuto #19179741)
Passenger side: 506-667 (RockAuto #19179738)
RockAuto.com has them for $105/ea.
Curious that the passenger side one has an issue...perhaps it's that one that is incorrect.
Old Nov 3, 2011 | 09:38 PM
  #39
asanti's Avatar
Holy Hell!! Good catch guys as I didn't even see that... I took a few quick pics w/ my phone just now, I'll upload he best ones here if the OP still needs them...
Later
Allex
Old Nov 3, 2011 | 09:44 PM
  #40
Powell Race Parts's Avatar
the first picture you posted shows the lower spring coil is not seated in the coil end recess in the strut.
that will make everything wrong.
Old Nov 3, 2011 | 09:56 PM
  #41
asanti's Avatar
Arghh! Can't figure out ow to make these regular sized and not thumbnails... Took the pics w/ my Evo 4 so I hope they help
Driver's side:
Passenger side:
Old Nov 3, 2011 | 10:28 PM
  #42
guys really.....think about it one has the stock spring, other has Pedder...........i have 2 for driver side too....
trust me that is not the problem...........
Old Nov 3, 2011 | 10:30 PM
  #43
what do you mean not seated correctly? its all way to the offset
please advise what exactly you mean by your statement or if have pictures of installation etc... would be great
Old Nov 4, 2011 | 02:13 AM
  #44
YelloEye's Avatar
^This post makes no sense, what are you referring to?
Old Nov 4, 2011 | 03:25 AM
  #45
RBC's Avatar
RBC
How is this a issue with the spring? No matter how much you change the spring the perch should never change in height. It is totally uneffected. The spring will only effect things above it. I'm looking at this on my phone but it looks like there is a spot on the bottom of the perch where the paint looks to be rubbed off like this has been an on going issue. The space looks so tight that heat expansion in the tires or over airing the tires would cause it to rub. Again I am looking at this on my phone so I may see something different on the pc. Get the alignment checked if the camber is as bad as you say it is. That would make up the difference. Something could have been thrown out of wack when you loosened everything up. As far as the struts being a different part number I have no clue on the hhr.
Old Nov 4, 2011 | 07:59 AM
  #46
in the picture of the struts side by side, people say its 2 passenger side parts............ i am confirming its same parts one with stock spring one with aftermarket one............
people were claiming that was my issue but its not the issue at hand
I took time to put the stock strut/spring on and clearance is fine, so its clearly the other strut..........which I do not get to be honest unless the strut is from a Cobalt maybe ?
Old Nov 4, 2011 | 12:26 PM
  #47
RBC's Avatar
RBC
So you swapped struts and springs? If that's the case put the new spring on the stock strut. Make sure the struts with the pedders are the same as the stockers. The one with the problem could be bent.
Old Nov 4, 2011 | 07:13 PM
  #48
another picture and email sent to show you how the lower spring coil must fit into the socket in thelower spring perch on the strut
Old Nov 4, 2011 | 07:21 PM
  #49
disregard the top spring hat thats for a Redline.Look at the bottom where the lower coil end "disappears" into the strut socket. Your spring end is visible in the photo you posted. Not seated. Spring is out of place as a result
Old Nov 4, 2011 | 07:49 PM
  #50
395 plus's Avatar
Originally Posted by Dart_SI
Don't feel dumb but the tire will never hit the strut. When u hit a bump it compresses, hence the spring being there. You could have 1 mm of clearance and it wouldn't hit.
Yes it would as you drive down the road the tires diameter expands due to centrifigul force and heat.
