Pedders installed wrong
Old Mar 15, 2011 | 06:22 PM
meckel's Avatar
Hey guys, I have had my pedders springs on my car for over a year now, and I noticed that on the drivers side on the rear it sits lower (small gap between wheel and fender) than on the passenger side, which sits noticably higher. I'll post pics when I can but does this sound like a spring isn't seated properly? It's been like this since day one a few years ago and hasn't noticeably affected the way the car drives or handles.
For reference, I can fit my ring and index finger between the top of the tire and fender lip when level with the top of the tire on the drivers side rear. On the passenger side, I can fit my pinky, ring and middle finger under the passenger side with room for almost another finger. I know it's a horrible description but it'll do till I can get some pics.
Old Mar 15, 2011 | 06:40 PM
Bl4des's Avatar
you spring is facing the wrong way all you need to do it turn the one spring
Old Mar 15, 2011 | 07:01 PM
meckel's Avatar
How do I do this? I didnt do the install, do you know which would be the one that was installed correctly, cause the car looks way better from the drivers side on the rear...
Old Mar 15, 2011 | 07:19 PM
sundevil07's Avatar
My ssc springs are doing this too, i have tried rotating them and have had them off twice now trying to figure it out. Theyre installed right and they were perfect on my lsj, i have no idea what happened but its really annoying walking to my car and seeing the passenger side noticeably higher. I have NO idea how to fix it
Old Mar 15, 2011 | 07:36 PM
meckel's Avatar
Hmm, are you having problems with the rear as well? I wish it was as simple as rotating it and then its done...
Old Mar 15, 2011 | 07:39 PM
1LowLS's Avatar
My ksports did that too before I cut them.I fixed it when I cut em though flamesuit on
Old Mar 15, 2011 | 08:07 PM
Bl4des's Avatar
the lower one is right
pull the back spring out and sit it on the ground it will lean one way. the way it leans faces the front of the car
Old Mar 15, 2011 | 08:10 PM
meckel's Avatar
Awesome, I'll have to get this looked at by somebody, No garage!! thanks!!
Old Mar 15, 2011 | 08:15 PM
Bl4des's Avatar
it is pretty easy just jack it up take wheels off 1 bolt on each side push down on the rear sub frame then try to get the spring out the are stuck in there pretty good
Old Mar 15, 2011 | 08:17 PM
whyyoumadson?'s Avatar
also check to make sure the springs are seated properly. the pedders are poorly designed on the bottom and a lot of people have issues getting the plastic retainer piece in. it might not have seated all the way when they installed it but from the weight of the car it might of finally compressed down on one side and not the other.....
Old Mar 15, 2011 | 08:18 PM
Bl4des's Avatar
he has had the springs in for more then a year the are seated by now
Old Mar 15, 2011 | 08:23 PM
yeah missed that...... try what blades says see what happens
Old Mar 15, 2011 | 09:01 PM
sundevil07's Avatar
I've literally tried all of the above and the SSC springs have a slant to then as well just slightly and its perfectly seated I seriously cannot for the life of me figure it out. Are there any more individual components that directly affect ride height like this?
Old Mar 15, 2011 | 09:07 PM
C_A_D88's Avatar
just noticed my pedders doing this today lol
Old Mar 15, 2011 | 09:10 PM
sundevil07's Avatar
Wonder if qwik has any insight on why this would happen on properly positioned and seated springs. Now I can't stop thinking about it lol
Old Mar 15, 2011 | 09:14 PM
SS SCHGD's Avatar
The drivers side has more weight more often! maybe it's just wearing more...Check your acompaning shocks too. and maybe rotate the springs?
Old Mar 15, 2011 | 09:22 PM
sundevil07's Avatar
13k miles I weigh 180 and I've rotated them a lot lol they are sitting in the exact same position looking at the bottom coils I'm about to rage why did you make this thread op!?! Lol
Old Mar 15, 2011 | 09:23 PM
08ssedan's Avatar
My pedders do the same thing.
Old Mar 15, 2011 | 09:28 PM
sundevil07's Avatar
The pedders people you most likely just need to rotate the springs to the correct position, brandon all you gotta do is jack up the rear NOT ON THE REAR BEAM and you will be able to move the springs without removing anything
Old Mar 15, 2011 | 09:45 PM
ronn's Avatar
I have Pedders installed correctly and I noticed the passenger side was about 3/8" higher...has not changed since install. I never measured stock, but it appears that this isn't out of the ordinary, since there are 4 here who have the same thing all on the passenger side. I know that difference is an *acceptable* difference within tolerances.
Were assuming that the fenders are symetrical, since that's what we're using here.
Old Mar 15, 2011 | 09:47 PM
SS SCHGD's Avatar
When I said rotate, I ment from drivers side to passenger side, not just spin them on thier mounts.....
You also might want to check the crown on the road/driveway your parked on too.
Old Mar 15, 2011 | 09:54 PM
sundevil07's Avatar
Good idea on actually switching them ill do it tomorrow and see what happens, I park in a garage so I'm all good there. Ronn let's get this figured out! Lol
Old Mar 15, 2011 | 10:53 PM
meckel's Avatar
Mine look the same way no matter where or how I park.
Old Mar 16, 2011 | 03:41 AM
onyx8's Avatar
Funny thing I noticed before I installed my pedders was that when I lightly tapped each spring with a piece of metal, they each had different sounding pitches. The fronts sounded exactly the same. Idk, this led me to believe that maybe the spring masses were slightly different...
Idk, its a silly story but I found it kinda curious.
Old Mar 16, 2011 | 03:46 AM
Dart_SI's Avatar
after i installed mine my car was noticably higher on the passenger side (id say about 3/4"). i took out the rears and looked at them, passenger side rear was upside down and not fully seated on the bottom plastic piece. so i flipped it and put it back in (with them facing the correct way also) and now its not noticable. fronts look perfect too. make sure they arent upside down. theres a way to tell.
