People with Pedders - ?
Old Jun 12, 2010 | 10:08 AM
  #401
jimbos'ss's Avatar
Originally Posted by ls1fbody
It is the RK sport one, and i don't think it covers the holes.
correct, gotta fill in the holes.
Old Jun 14, 2010 | 07:52 PM
  #402
Evoly's Avatar
I'll follow up on Distillion's Pedders pic. Here's mine!
Old Jun 14, 2010 | 11:01 PM
  #403
SKCobalt's Avatar
I suppose I could post a couple of mine.
Old Jun 17, 2010 | 11:34 AM
  #404
qwikredline's Avatar
^^^^^ wow! that looks awesome. Blue car.
Old Jun 17, 2010 | 01:09 PM
  #405
spike's Avatar
will some one with pedders measure from the ground to the top arch of the fender (front and rear) for me...
Old Jun 17, 2010 | 01:52 PM
  #406
around 25 3/4 front to 26 1/4 or 1/2 rear....depends on tires etc.
slammed on HSD or Stance is about 25 1/4 all round
Old Jun 17, 2010 | 02:14 PM
  #407
spike's Avatar
Thanx qwik
Rite now I'm @ 26 1/4 front and 26 3/8 rear with sportlines but I have remove a lot of weight. I'm scared the pedder will be 4x4 status. I may go coilovers just 2 get a got stance, not slammed just raked alittle
Old Jun 17, 2010 | 02:40 PM
  #408
ls1fbody's Avatar
Haz l33t wheelz.
i'm at 25 1/2 in the front, rear is irrelevant
Old Jun 17, 2010 | 04:49 PM
  #409
Stamina's Avatar
Originally Posted by spike
Thanx qwik
This is what Pedders coilovers look like:
Set to height they came set with. Used rack spacers. I was worried that the back dampening adjustment knobs would be hard to get to, but all you have to do is reach through the wheel, turn them, and count the clicks. Very easy. Just make sure that you're turning them the same way, since they are mounted differently in relation to how you're looking at them when you do it.
Old Jun 17, 2010 | 06:57 PM
  #410
arman14's Avatar
Does anybody else has uneven ride height in the rear?
I noticed the rear drivers side is a little higher than the rear passenger side.
Old Jun 17, 2010 | 11:31 PM
  #411
007CobaltLS's Avatar
I noticed the readr drivers side is a little higher than the rear passenger side.
I will have to look at the car with Pedders, I noticed this when I had my Sportlines on though. Always bugged the **** out of me...never figured out what it was either.
I don't think I have that problem now though.
Old Jun 18, 2010 | 12:10 AM
  #412
arman14's Avatar
Please take a look of your car and let me know, I also have a little negative camber on the side that sits higher than the other
Old Jun 18, 2010 | 11:34 AM
  #413
spike's Avatar
i remeasured last nite and my numbers were off just a bit
its 26 1/8 on the front and 26 1/2 in the rear on 235/45/17's
Old Jun 18, 2010 | 01:06 PM
  #414
SKCobalt's Avatar
Thanks! I'm going to try to install the steering rack spacers tonight! Then the suspension is pretty well done. On to engine stuff then I guess!
Old Jun 18, 2010 | 01:29 PM
  #415
Stamina's Avatar
The passenger side is a piece of cake. The driver side is harder, not because it's any different really. It's just that it's hard to get to.
Tip: After doing one side, don't tighten it all the way back down until you get the other side on. It'll give you more slack to work with that way. I figured it was common sense until I witnessed somebody do it and then have a ton of trouble with the other side. lol
Old Jun 18, 2010 | 09:14 PM
  #416
^^^^^this
Old Jun 18, 2010 | 09:54 PM
  #417
I would like to add this to the above...do the driver's side first...since it's harder, you will get the frustration out of the way and when the passenger side is done and it's all done, you'll be happy.
I do agree with the above totally. That's how I did it.
Old Jun 18, 2010 | 11:18 PM
  #418
SKCobalt's Avatar
Thanks for the advice guys. I will do that for sure. I have an air ratchet which will hopefully fit in and make it a bit faster!
Old Oct 17, 2010 | 02:59 PM
  #419
RBC's Avatar
RBC
I was hesitant at first to lower my car due to the fact it was our only car and did not want a harsh ride for my daughter. I just recently purchased my wife a ford escape so the car is mine to do what ever I wish. So my first thought in springs are the pedders. My big question is to those that are running 245/40-18's or bigger. Do you guys have any rubbing issues? I'm running 245 falkens on stock wheels and no problems on stock ride height. With the pedders what is the biggest tire people have ran without any problems?
Old Oct 17, 2010 | 03:19 PM
  #420
arman14's Avatar
I'm running 245/40/18s on the rear and have no problems at all
Old Oct 17, 2010 | 04:25 PM
  #421
RBC's Avatar
RBC
Your just running them on the rear?
Old Oct 17, 2010 | 04:27 PM
  #422
arman14's Avatar
Yes, I'm running 225/40/18s on the front.
Old Oct 17, 2010 | 04:29 PM
  #423
Maupin SS/SC's Avatar
why....
Old Oct 17, 2010 | 06:49 PM
  #424
RBC's Avatar
RBC
Yes, why?
Old Oct 17, 2010 | 06:54 PM
  #425
JonyyB's Avatar
Site Founder
I am running 235/40/18 on wider 18x8.5 wheels and have no problems (offset is not for cobalts on these too...35mm)
I'd give it a shot. Don't think it's gonna be a problem with the stock wheels
