progress lowering springs
i have a ? about progress springs. i was wondering if they will help out with my handling or will they just lower the car. im happy with the way my car handles but beter is well always beter. Also i was wondering if i am able to use stock struts with the springs. and if there any other springs that are beter let me know
alright, Most lowering springs will help with handling as they will give you a lower center of balance. I have the SSC springs and there great. You can use your stock struts. The biggest difference is your cars ride will be stiffer.
i like the progress springs.... looks great and also helps with handling. i used stock struts and they do fine, you just have to cut the bump stops in half. progress rear sway helps alot with this kit also
