Pulling but can't figure out why
Ok here's my problem. Sometimes actually a lot of times when coming to a stop (braking or engine braking it does it for both) the car pulls to the right. Sometimes the left but mostly the right. Now I don't think it's a alignment issue because I tried taking my hands off the wheel while driving and it stays straight. I don't think it's the brakes because I tested it by doing some hard braking stops and there was no pulling. And also cause it does it with engine braking too. The ONLY thing left is my strut bar. Is there ANY possibility for that being the problem? Because I don't remember having this issue pre strut bar it pretty much started after. Or is it the roads suck here and being that the suspension is stiffer, it just experiences bump steer more? It's rather annoying because I have to fight with the steering all the time when it happens! It pretty much only happens slowing down but like when I approach slow speeds like 15mph or lower.
But what about the fact that it started doing this after I installed the strut bar? Is it cause it being more stiffer make it more sensitive to bumps? None of the other cars in my family do this... And I'm pretty sure it didn't before the strut bar.
Strut bar won't change almost ANY part of your driving dynamics because of where the strut towers are.
Strut bar is a 'bling' mod on Cobalts.
It is more than likely the crown of the road, and nothing to worry about.
And yes I know any car can get torque steer.
My old car did this and it ended up being a braking problem. Really it could be alot of things even under inflated tires. The strut bar probably not unless you installed it in the wrong location Highly unlikely
