Rear hub bearing, help
Old Jul 27, 2013 | 12:35 PM
Darknight23's Avatar
I can't find a anything on how to change the rear hub bearing for the SS/SC. Anyone know? I just don't know the torque specs for the 4 bolts. Also looks like you need to take the spring out to do the job.
Old Jul 27, 2013 | 04:47 PM
QuickShift's Avatar
I just did the rear without taking the spring out or dropping the axle but I used an 18" extension...Not sure of the torque specs..
Old Jul 27, 2013 | 05:01 PM
CannonBalt's Avatar
For the main hub bolt? 85 FT/LBS.
Old Aug 12, 2013 | 08:15 PM
No the 4 bolts on the back of the rear hub assembly. From what I could find it was under 40 ft/lbs
Old Aug 13, 2013 | 04:20 PM
CannonBalt's Avatar
35 ft/lbs
Old Aug 16, 2013 | 07:27 PM
BLKLS's Avatar
I did the. With the springs in, just use an extension. A wobble extension will help.
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
Sep 30, 2015 07:22 AM
cw383
Sep 30, 2015 12:41 AM
Bohb
Sep 27, 2015 09:11 PM
