Rear sway bar
Old 01-15-2010, 03:50 PM
Pursuit_Gt's Avatar
Rear sway bar
So i have gone through the search, read up on as much info as i could on adding a rear sway bar to my Pursuit Gt...but i have also read on how its not entirely necessary seeing that the cars already come equipped with one.
The car will be running the road course this summer and i have lowering springs (ssc) but its also my daily driver...
Is it going to benefit adding a rear sway bar? or should i go ahead and replace both front and rear ?
Old 01-15-2010, 03:54 PM
Haz l33t wheelz.
ls1fbody's Avatar
It will benefit you to replace both actually. I would recommend the FE5 front sway bar found in any of the SS Supercharged or SS Turbocharged Cobalts, along with the OTTP Street Rear Bar.
Old 01-15-2010, 03:57 PM
SKCobalt's Avatar
x2 on the OTTP swaybar. Mine is on order and I can't wait (well and also for spring!). Just a question as I'm unfamiliar with the Pontiac suspensions for this platform. Doesn't the Pursuit GT have th FE5 swaybar from the factory?
Old 01-15-2010, 03:59 PM
Haz l33t wheelz.
ls1fbody's Avatar
no, it has the FE3 since it's the same as the 2.4 SS, or Sport model Cobalt.
Old 01-15-2010, 04:53 PM
SKCobalt's Avatar
Good to know. I thought there was a mid suspension between the FE1 and the FE5 just couldn't remember.
SSLOW06
10-01-2015 07:21 PM
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
anotherslowlnf
09-29-2015 03:52 PM
09-26-2015 06:44 PM
Quick Reply: Rear sway bar
