Reconnect Front end link?
Old Jun 5, 2010 | 10:41 PM
BlackyK's Avatar
I just replaced my driver's side axle and everything went smoothly until I saw the lower connection for the Stab. bar had popped out. How does it go back in? Does it just pop back in with a C-clamp?
Old Jun 6, 2010 | 12:29 AM
SSchargedSS's Avatar
popped out? it just goes through the hole and you tighten the bolt
Old Jun 6, 2010 | 06:15 AM
BlackyK's Avatar
The bolt with the round ball stayed put. The part that pops onto the bolt is what came off.
Old Jun 6, 2010 | 07:17 AM
constantproject's Avatar
sounds like you need new end links
Old Jun 6, 2010 | 07:39 AM
BlackyK's Avatar
How did it pop out? They aren't damaged.
Old Jun 6, 2010 | 08:24 AM
06G5GT's Avatar
It had to be previously worn. They certainly don't come apart easily and it's a waste of time to try to put it back together. Buy a new one.
Old Jun 6, 2010 | 08:49 AM
BlackyK's Avatar
Heh well I will have to do that then, but in the mean time I used vice grips to wedge it back in. I remember what a PITA it was removing the top bolt of the end link when I put the Sportlines in. I guess I'm in for another headache. Should I replace both sides if the passenger side is still OK?
Old Jun 6, 2010 | 08:52 AM
rallyracer's Avatar
Yes!
...unless you plan on buying GM ones again, which I wouldn't do.
Old Jun 6, 2010 | 09:32 AM
Wangspeed's Avatar
Your other option, til you can get replacements, is to simply remove one of the endlinks. This will keep that ball joint from suddenly popping out, and having the sway bar whack the remaining ball joint. I prefer safely disabled over waiting for it to break again, but it's up to you.
I've got powergrids, and they're nice, but honestly, unless you're considerably dropped, they aren't worth the price. Just get Moogs, or FE5.
Old Jun 6, 2010 | 11:40 AM
oh damn man, I didint think they popped out like that. Ya its shot.. Moog makes excellent replacements I got them on my car, no problems. good luck man
Old Jun 6, 2010 | 11:59 AM
thefishyisblue's Avatar
this.
Old Jun 6, 2010 | 08:13 PM
BlackyK's Avatar
Thanks for the continued feedback guys! Where can I get Moogs? CED? And I'm on Sportlines, have been for a solid year now.
Old Jun 6, 2010 | 08:33 PM
CordiaDOHC's Avatar
Moogs are available at Napa or Carquest to my knowledge. Have them on my car thanks to advice given from maven to run them.
Old Jun 6, 2010 | 08:43 PM
YelloEye's Avatar
How much did those run you Cordia?
Just checked Summit Racing, there's a note on them that says "Does not fit FE5 suspension" hmm...
Old Jun 6, 2010 | 08:46 PM
CordiaDOHC's Avatar
Think they were like 60 ish for both sides. They are far stronger than stock and have a grease fitting on them as well. Plus theres more meat on them to get a wrench onto for when you need to remove them. So definitely recommend them. Unless you have the money and the desire to get the powergrids.
Old Jun 7, 2010 | 12:28 AM
a lot of places carry moog. I find the best prices by typing in year, model, part in google and clicking shopping.. pulls up cheapest parts :-P just verify its the right part
Old Jun 7, 2010 | 09:27 AM
BlackyK's Avatar
I saw those yesterday and those particular ones don't look like the ones on our cars.
Old Jun 7, 2010 | 11:44 AM
YelloEye's Avatar
I saw that too but the picture is only a representation of the product and may not be the particular picture for your vehicle. Or thats what it said anyways.
Old Jun 7, 2010 | 11:50 AM
Illini_06SS's Avatar
I suggest just getting the Moog ones designed for the FE5. They have a larger hex portion (so they don't strip like the stockers when you try to take them off...) and are nice and stiff for better handling
I bought mine at O'Reilly's. I think Autozone sells them too. There are 2 lengths, get the ones that are shorter (they're the FE5 ones).
Last edited by Illini_06SS; Jun 7, 2010 at 11:50 AM. Reason: Automerged Doublepost
Old Jun 7, 2010 | 12:39 PM
YelloEye's Avatar
Non adjustable right? Heres what I found for O'Reilly's:
$33.99 each
Old Jun 7, 2010 | 12:45 PM
$33.99 each
Unless you are REALLY low, there's no need for adjustable endlinks. Those are the ones that I'm referring to. They went on super easy, but be prepared to take a torch to the stockers to get them heated up so you can blast them off with an impact wrench...
Old Jun 7, 2010 | 12:59 PM
YelloEye's Avatar
I've already taken the top nuts off once when I did my springs last month so they should be fine. The lowers cant be that much harder....but yes impact = win
Solaris99
28
Mar 15, 2017 01:22 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Bohb
Sep 27, 2015 09:11 PM
grampss
Sep 27, 2015 08:51 PM
