Second best will have to do
Old Jan 4, 2006 | 11:47 AM
BobWreck's Avatar
According to Shox.com, Bilstein shocks will not be available for 2006 base Cobalts for at least 9 months. As good as Bilsteins are, I'm not willing to wait that long. Do you have any suggestions for shocks? I intend to use Eibach Sportline springs.
Thanks,
Bob
Old Jan 4, 2006 | 11:51 AM
R33P3R007's Avatar
360 L337 User
the stock ones will work fine.
Old Jan 4, 2006 | 12:07 PM
BobWreck's Avatar
Thanks a ton. I hate spending money.
Even though a search didn't help answer my question, a post on the same page as this one did. Dang it. I keep forgetting it's READ then POST.
Bob
Old Jan 4, 2006 | 04:47 PM
IonNinja's Avatar
But for how long? Just because we don't have any struts available doesn't necessarily mean stock ones are okay.
Old Jan 4, 2006 | 04:51 PM
Brandon97Z's Avatar
koni's should be out at the end of Janruary. I made a post about it not long ago
Old Jan 4, 2006 | 04:53 PM
Brandon97Z's Avatar
And do not put sportlines on stock struts. Especially base struts at least the SS's have a little stiffer strut but i still wouldn't recommend it either way. It will cost more in the long run.
Old Jan 4, 2006 | 05:20 PM
hardtocope's Avatar
isn't koni harder to install on our cars since the whole shock is adjustable.. i want a shock that i can just put on with out adjusting anything and worrying about if i did it right.
Old Jan 4, 2006 | 06:57 PM
Brandon97Z's Avatar
Don't be scared of adjustablity, embrace it. Really we won't know until they are out as far as ease of install. Shouldn't be anything difficult to adjust them as they are externaly adjustable i believe.
Old Jan 4, 2006 | 07:13 PM
hardtocope's Avatar
i'm going to bring my car to the dealer to install the springs a shocks but if i get koni's then i really doubt the dealer will know how to properly adjust them.. they prolly just screw it up
Old Jan 5, 2006 | 02:04 AM
Eddie's Avatar
stock shocks will not be fine, get koni's and be done w/ it, and you'll never have to worry about shocks again, koni's are the best shock out there, better than belstien. wait for koni's if u lower your car on stock shocks, expect to spend more in the end for having ro replace strut mounts and possibly wheel bearings due to blown shocks, just wait. why buy a new car to mess it up buy not doing something correctly.
Old Jan 5, 2006 | 02:16 AM
CobaltSS422's Avatar
I'm not sure if I agree.. Don't get me wrong.. Koni's are good but Bilstein's are the best.. IMO.. German Engineered.. No Offense to anyone but those German's sure know how to make a car handle like a dream!!
Old Jan 5, 2006 | 12:48 PM
hardtocope's Avatar
i think i'm going to wait for bilstein shocks to come out.. koni's seem like to much of a headache in installing. does anyone know how much money a set of four bilstein shocks will prolly go for in our cobalts?
Old Jan 5, 2006 | 09:58 PM
Brandon97Z's Avatar
If your having a shop install them for you any competant suspension shop should be able to do it. Bilstein shocks i would say are better then koni but not by much. Not to mention Bilstein are usually pretty expensive. Like close to $1000.
Old Jan 5, 2006 | 09:59 PM
hardtocope's Avatar
i'm going to have the dealer install them
Old Jan 5, 2006 | 10:18 PM
Brandon97Z's Avatar
All you do is turn a knob to adjust them. Koni sends directions that says how to adjust them and even gives you tips on setting your suspension up like what certain adjustments will do to the handling of the car(ie stiffer settings in different corners of the car). But seems like you have your mind made up on Bilstein for whatever reason so wait a year for them to come out and spend more while your at it then you would for koni's.
Old Jan 6, 2006 | 12:09 PM
BobWreck's Avatar
Koni's were suggested by the guy at Shox.com. I've had them on motorbikes before, Koni makes a good product.
Bob
Old Jan 8, 2006 | 12:16 AM
BobWreck's Avatar
I just installed some 17x7 Motegi MR7s with some Toyo Proxes FZ4.This comination is about 3/4" taller than the stock wheel/tyre. I believe the Sportlines will be ok with the stock shocks. Well, hopefully they'll last long enough for the Bilsteins to be available.
Bob
Old Jan 8, 2006 | 05:57 PM
BooSSted's Avatar
Ok, free lesson time. Installing a Koni shock is no different than installing a stock one. The adjustment takes place after installation. All you are doing with the adjustment is changing the stiffness of the strut. Have nothing to do with height or anything like that.
Running the sportlines on the stock struts will not cause you a problem right away. You will probably get 6 months out of the stock SS struts, less on base model struts. Ideally, if you want to do it in the most economical way, you will swap the whole suspension when doing the upgrade, that way you can swap it back to stock if you sell the car or if you need to drive it in the winter.
Has anyone heard any talk of a full coil-over kit yet? That is what I am holding out for!!
Old Jan 8, 2006 | 10:07 PM
Doc's Avatar
Doc
RKSport list some for the 2005 2.2L http://www.rksport.com/product/p_12035075/view_detail
I emailed H&R and they didn't have anything for the SS/SC. I didn't ask about other versions of the Cobalt. They said it was in R&D for the SS/SC, without an expected date.
Old Jan 9, 2006 | 10:09 AM
celicacobalt's Avatar
damn we need some new shocks
