Should i drop
yea all the suspensions are interchangeable..
so any springs made for a cobalt will fit ALL cobalts
I had the Tenzo's and they rode decent.. Can get a little bumpy at times though.. remember the lower you go the stiffer the ride will be
im still stuck, because idk how low i will sit with my LS, cause i want to throw on a body kit on it, and i wont wanna scrap the rode, & idk how high the cobalt is stock..
should i go --
2.0 Inch Drop (F) & 2.5 Inch Drop (R), For Chevrolet Cobalt 05-07
or
1.5" front & 1.4" rear
should i go --
or
well if you are getting a kit and are afraid of scraping I would go with the higher setup cause that will give you better clearance
Also again.. the higher the springs are the better they are going to ride
this is the body kit i want
http://www.everythingcobalt.com/cata...x-p-13975.html
If you have larger than stock rims dont be suprised if they scrape. also have fun with the front struts... they are a real bitch to remove when not using air and they still arent cake when using air.
