Softer suspension?
Old Jun 8, 2011 | 01:04 PM
smd5231's Avatar
Softer suspension?
My factory 'sport-tuned' suspension on the 2008 Cobalt Sport 2.4 (non-turbo) is getting to me. I use the car mostly for city driving and I can feel every pothole I hit. Is there anything I can do to the suspension to make it SOFTER? I don't race and don't do any off-roading. I just want my car to provide a comfortable ride on bad roads. Thanks!
Old Jun 8, 2011 | 01:47 PM
Sweetsandman's Avatar
Get an LS (FE1) suspension
/Thread
Old Jun 8, 2011 | 01:55 PM
RoadconeTuning's Avatar
sell it and buy a used caddy? you drive a "sporty" fwd car with low profile tires and a stiff suspension...
Old Jun 8, 2011 | 01:56 PM
JcNacho's Avatar
There are a few things you can do:
1. Check the tire pressures. a higher pressure will make for a harsher ride. Between 32-35psi would be the lowest I would go. any lower and you will have issues with tire wear and rim damage if you hit a pothole.
2. Get a different set of rims and tires. The stock sport rims and tires are 17" with 205-50-17 tires. For a 17" rim this is a fairly big sidewall. If you stepped down to a 16" you could put a 205-55-16 that will be the same width, but have a larger sidewall. The larger sidwall will soften the ride a little and will reduce handling slightly.
3. You could change out your FE3 springs for the FE1 springs. This will definately soften the ride and will probable feel floaty compared to your current setup.
Those are just a few things off the top of my head. I am sure that others may have different or better solutions. Good Luck!
Old Jun 9, 2011 | 09:28 AM
swap out tires for some luxury touring tires and add weight to the body of the car...
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
