Squeaky Suspension Fix?
I tried searching, but couldn't find anyone with a fix...
My car's suspension is squeaking/creaking. It's cold out, 65,000 miles. I've heard people say it was the suspension bushings. Others suggested possibly the struts. Makes the noise when going slowly over speed bumps, in both the front and back.
Has anyone had this and made it go away? Perhaps if you've replaced the bushings? I'm not sure if any vendors make replacement bushings that might make this go away. Or perhaps just having a mechanic regrease what I currently have.
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
First of all, it's sway bar bushings he's talking about not control arm bushings.
Secondly, if you remove them and lube them, the noise will go away briefly. Maybe a few weeks.
When the rubber starts to get old, it squeeks over bumps. It's not going to hurt anything but the noise will drive you nuts.
I'm not crying, I just have money and want to fix it. None of my previous cars squeaked like this unless something was broke. And it didn't start until over 60,000 miles, so it seems like something, maybe the bushings, may have worn out.
If its the front antiroll bar bushings replacing them will fix it, so will cleaning the bar and the bushing, or lubing the bushing, or wrapping the bar in carbon cloth in the bushing. Since its front and rear youve probably either just got a squeaky car, or some loose fasteners somewhere.
I just started having this exact same problem at about the exact same mileage. Mine however seems like it's on in the front. I'm getting the squeaking on slow driving over bumps, but I'm also getting a rattle in my front suspension to at slow speed over semi-to rough terrain.
So someone who won't B.S. me, What do I NEED to replace to make this stop?
Thanks in advance,
Tom
Thanks in advance,
Tom
Thanks in advance,
Tom
Thanks in advance,
Tom
Hey Mavenif the bar is not a double bolt clamp( 05-06, all LS?) could that allow squeaking? the pillow would bend up and itch?
I think I might try replacing the bushings in my strut towers when it gets a little warmer out and see if that fixes it. Anyone have an idea of the approximate life of our struts themselves? I have 68,000 miles on mine.
Thanks in advance,
Tom
Thanks in advance,
Tom
Anyone who gives you a mlieage is trying to sell you struts.
DANRICKARD
Oct 1, 2015 12:08 AM
