ss with sportlines question
when lowering a ss/sc on sportlines do i need to c-cut anything to get a good alignment. Or can i just put these springs on it and get it alligned with no problem? Also will the ss rub with sportlines and factory 215/45/18 tires?
no one has had any problems with rubing so far, just put them on and plan on replacing the shock and struts a little sooner then normal.
also most people have said that the alignment was not necessary for the SS/SC, but I there is an alignment kit available. to correct the slight camber change
No rubbing.
No cutting.
Alignment a week and half later and one tire was minor toe out. No kit.
Dropped the front 1 3\4"
Dropped the back 2"
Handles better. A bit stiffer over speed bumps.
No cutting.
Dropped the back 2"
Mine are getting installed here in like 30 minutes and the instructions say to cut the bumpstops but im not sure if the dealership is going to or not. I have 225/45/18 and i heard they dont rub but ill let you know
