SSC/CM lowering springs
#101
AWD > FWD
it's not that it will actually be lower, but parking on certain hills looking at it from certain angles can make the car look higher or lower. I can show you two pics of my car in the same spot from the front and the back and you would think it was on 2 different sets of springs but the car never moves.
#106
Yep...I've got the Cobalt SS CM springs installed and I still have a little more height in the rear. It doesn't look bad though.
#107
the cars lines also are raked (alot of nwer vehicles have raking in the body designs), if u look u can see the line runnin from headlamp all the way to the rear is raked. so even with my side skirts parallel to the ground it still looks raked . pic below shows what i am saying.
#108
Well after speaking to a rep today at CM I was told that the spring rates for the SS springs are:
135 front
150 rear
and the HHR springs are:
240 front
160 rear
My question is would the HHR springs work well for a cobalt, the higher spring rates being better for handling? Or because the rear is so low would it not be okay? Maybe the cobalt front springs and hhr rear springs would be good.
135 front
150 rear
240 front
160 rear
#109
#110
yeah, the headlamp is cheap ass sonar brand and began to crack a billion little cracks. I am currently aquiring supplies to do a retro fit stock set up. (iwill put another eyebrow on the inside).
#112
It doesn't drop .5 in the rear. It's 1.5inches. I just installed mine. And I guess I got lucky because my car just about sits leveled. The back isn't much higher than the front.
#114
yea i know, i saved your email that you posted here. but the ppl that they have working there dont know wtf they are talking about. thats what pisses me off. whatever, hopefully they will settle a bit with time.
#120
I've been worried about this, I'm about to install mine today. I'll be demanding a refund if it is .5 because I also emailed them prior making sure they didn't change their springs.
