Steering Rack Vibration
Old Oct 11, 2017 | 11:20 AM
SChassisMostly's Avatar
Just want people's opinions on this matter. Lowered my 09 LNF on B & G springs and new struts so I bought OTTP's steering rack spacers so that I wouldn't get bind on full lock. Installed them and since then, I noticed my steering column seems to vibrate pretty bad over bumps and dips in the road. It's not bad but I can hear it all the time. Took the wheels off again when I changed out sway bar bushings/LCA bushings/sway bar endlinks and tightened them down but I still get it. I just got on ZZP's website and they now offer them but it has a machining in the center that seems like it would fit the lip of the rack better. Has anyone had these issues before?
Old Oct 11, 2017 | 12:36 PM
jdbaugh1's Avatar
Did you confirm that the bolts holding your steering rack are tight and holding it in place firmly?
Old Oct 11, 2017 | 12:38 PM
Yes they are tight but there is a lip on the underside of the rack that keeps it from sitting flush against the rack.
Old Oct 11, 2017 | 12:53 PM
double clutch's Avatar
Did you get the correct size spacers?
Old Oct 11, 2017 | 01:09 PM
There is no size difference besides the thickness of it. The B & G springs drop it like 1.75 inches so I got the corresponding spacer. Is the rack and pinion the same on all Cobalt models or do the SS's have a faster ratio?
Old Oct 11, 2017 | 01:11 PM
All the steering racks are the same
Old Oct 11, 2017 | 01:34 PM
jdbaugh1's Avatar
Could you put up a picture of this so we can see what it looks like? Could be your issue.
Old Oct 11, 2017 | 01:36 PM
I will later when I get home
Old Oct 14, 2017 | 07:58 PM
cobaltssdude420's Avatar
What size endlinks did you get? Get A keyhole spacer as well. It raises the engine to help align the axles
Old Oct 16, 2017 | 01:24 AM
bahoodle's Avatar
try putting ur back tires on the front.. if it goes away or gets worse its ur tires or all the extra negative camber from lowering it. if u see the camber thats a problem :P
