Steering wheel does not self center after right turns
Okay so if I make a left turn and let go of the wheel, it will self-center itself. If I make a right turn, I get "memory steer", the wheel does not self-center.
I know caster self-centers the steering wheel after taking a corner, however I've checked EVERYTHING! I'm pulling my hair out..
You've never been in an accident, even a minor bump against a curb? When was the last time you had an alignment? Not much to say unless you can show us an alignment sheet.
You do have enough air in all the tires, right?
Alot of times its caused by bind in the steering. Either in the rack, tie rods ends, or ball joints. Something is out of wack and is getting bound up. check your strut bearing plate too.
